Wrote a script that loads a lisp which has a cond to load another lisp if the dwg file is the same name as the lsp file. Runs fine if I load it in any of the specified drawings and outputs pdf files expected. However when I use it through script pro 2 it crashes on any one of the given drawings. In the script pro log it the error says it cant read the dwg log file but it still generates 2/3's of the sheets to pdf. Most of my searches on this came back relating to the script pro log not the drawing file log. I did see one thread where it talked about adjusting the timeout setting in script pro but I don't know if that is just a best guess for timeout if it is the issue. Being as it works loaded into a single drawing I havn't messed with it yet. Any ideas on this?
Here's the code, only difference is I have a bunch of conditions in the "PDF ALL PACKAGES.LSP" that just have different corresponding dwg and lsp file names. If I load "PDF ALL PACKAGES.LSP" into any of the drawings in the condition it works fine, it's just when I run it with the script it generates about 2/3's of the sheets to PDF's. When it does error autocad closes reopens then closes and script pro then asks if I want to see the log file. The log file from script pro says;
[Status summary]
Failed
Error while reading log file for M:\CAD\MY DRAWING.dwg
So that's where I'm at still so far, perhaps there is a better way to accomplish this. I have 30 or so drawings I was just going to let run through scriptpro 2.0 until it erred.
Script code:
(load "M:\\CAD\\LISP\\PDF ALL PACKAGES.LSP") PDFALL
(defun C:PDFALL (/) (cond ((= (getvar 'DWGNAME) "MY DRAWING.DWG") (load "M:\\CAD\\LISP\\MY DRAWING.LSP")) ) (C:PDFPACKAGE) );end
(defun C:PDFPACKAGE (/ layouts num ) (command "_DATALINKUPDATE" "_U" "_K") (setq layouts (layoutlist);list all paperspace layouts in the drawing num 0);zero counter (repeat (length layouts);Repeats the plot command on all layouts (cond ((= (nth num layouts) "Sheet 5");flags sheet 5 for layer varibles (command "-layer" "p" "n" "ER400|A-CTRAY,ER400|A-EFIXT,ER400|A-EQPM" "");turns on/off xref drawing layers for plot );Sheet 5 Condition ((= (nth num layouts) "Sheet 6");flags sheet 6 for layer varibles (command "-layer" "p" "p" "ER400|A-EQPM" "");turns on/off xref drawing layers for plot );;Sheet 6 Condition ((= (nth num layouts) "Sheet 7");flags sheet 7 for layer varibles (command "-layer" "p" "n" "ER400|A-EQPM" "p" "p" "ER400|A-EFIXT" "");turns on/off xref drawing layers for plot );Sheet 7 Condition ((= (nth num layouts) "Sheet 8");flags sheet 8 for layer varibles (command "-layer" "p" "n" "ER400|A-EFIXT" "p" "p" "ER400|A-CTRAY" "");turns on/off xref drawing layers for plot );Sheet 8 Condition );; cond (command ".-PLOT" "Y" (nth num layouts) "DWG TO PDF.PC3" "ANSI D (34.00 X 22.00 INCHES)" "I" "L" "N" "W" "0,0" "34,22" "1:1" "C" "Y" "Black & White.ctb" "Y" "Y" "N" "N" (strcat (getvar 'DWGPREFIX) (vl-filename-base (getvar 'DWGNAME)) " " (getvar 'CTAB) ".pdf") "N" "Y");pdf plot routine (setq num (1+ num)); Increment counter ); end repeat (command "-layer" "p" "p" "ER400|A-EFIXT,ER400|A-EQPM" "");turns plot layers off back on ); end
Hi Christopher,
unfortunately, I can't see anything wrong with your codes... nor the error reason...
Henrique
