Visual LISP, AutoLISP and General Customization
Active Contributor
macuma
Message 1 of 6 (244 Views)
Accepted Solution
Saveas using Lisp Or Vlisp
244 Views, 5 Replies
02-04-2013 05:12 AM
Is it possible to call the saveas command with the dialog showing with the filename already set by a variable?
Have already tried (initdia)(command "saveas" "" "MyDrawing") and (initdia)(vl-cmdf "saveas" "" "MyDrawing").
If running from a new file the filename in the dialog is always populated as "Drawing1"
*Expert Elite*
Kent1Cooper
Message 2 of 6 (235 Views)
Re: Saveas using Lisp Or Vlisp
02-04-2013 05:54 AM in reply to: macuma
Look into the (getfiled) function, which has an argument for a default file name.
Kent Cooper
Active Contributor
macuma
Message 3 of 6 (229 Views)
02-04-2013 06:11 AM in reply to: Kent1Cooper
Thanks Kent. That does the trick if it can't be done direct from the command.
Active Contributor
macuma
Message 4 of 6 (188 Views)
02-20-2013 03:30 AM in reply to: macuma
Only just got round to fully testing this. It accepts the variables but can't be used to save, only to open an existing file.
Active Contributor
macuma
Message 5 of 6 (183 Views)
02-20-2013 03:44 AM in reply to: macuma
Sorry, this does work. Didn't read the flag settings correctly.
*Expert Elite*
pbejse
Message 6 of 6 (181 Views)
02-20-2013 03:46 AM in reply to: macuma
(setvar 'expert 5)
(setq fn (getfiled "Save drawing as" (strcat (getvar 'dwgprefix) var) "dwg" 1))
(command "_save" fn)
HTH
You are not logged in.
Announcements
Need installation help?
Ask the Community
