Saveas using Lisp Or Vlisp
5 REPLIES 5
itmanagement
574 Views, 5 Replies
Is it possible to call the saveas command with the dialog showing with the filename already set by a variable?
Have already tried (initdia)(command "saveas" "" "MyDrawing") and (initdia)(vl-cmdf "saveas" "" "MyDrawing").
If running from a new file the filename in the dialog is always populated as "Drawing1"
5 REPLIES 5
Kent1Cooper
in reply to: itmanagement
Look into the (getfiled) function, which has an argument for a default file name.
Kent Cooper, AIA
itmanagement
in reply to: Kent1Cooper
Thanks Kent. That does the trick if it can't be done direct from the command.
itmanagement
Only just got round to fully testing this. It accepts the variables but can't be used to save, only to open an existing file.
itmanagement
Sorry, this does work. Didn't read the flag settings correctly.
pbejse
(setvar 'expert 5)
(setq fn (getfiled "Save drawing as" (strcat (getvar 'dwgprefix) var) "dwg" 1))
(command "_save" fn)
HTH
”Boost
