Visual LISP, AutoLISP and General Customization
Saveas using Lisp Or Vlisp
5 REPLIES 5
578 Views, 5 Replies
Is it possible to call the saveas command with the dialog showing with the filename already set by a variable?
Have already tried (initdia)(command "saveas" "" "MyDrawing") and (initdia)(vl-cmdf "saveas" "" "MyDrawing").
If running from a new file the filename in the dialog is always populated as "Drawing1"
5 REPLIES 5
Kent1Cooper
Look into the (getfiled) function, which has an argument for a default file name.
Kent Cooper, AIA
in reply to: Kent1Cooper
Thanks Kent. That does the trick if it can't be done direct from the command.
Only just got round to fully testing this. It accepts the variables but can't be used to save, only to open an existing file.
Sorry, this does work. Didn't read the flag settings correctly.
pbejse
(setvar 'expert 5)
(setq fn (getfiled "Save drawing as" (strcat (getvar 'dwgprefix) var) "dwg" 1))
(command "_save" fn)
HTH
”Boost
