I'm working on a routine to copy objects from blocks and x-refs into the current drawing using refedit. I've got 2 big problems:
1. I need to save the CP selection window so it can be applied to each selected x-ref / block.
2. When running the refedit routine, I need to change the settings for "Create unique layer, style, and block names" and "Lock objects not in working set" but can't seem to find where these variables are.
Solved by dbroad. Go to Solution.
Added (setq REMSET nil) as you suggested
Removed (repeat function as you suggested
Removed unnecessary atoms
(defun C:COPYX (/ CMD PICK1ST PT PNT POINTLIST XR XREF ENTCNT REMSET)
Already used this to create 3 exhibits this AM in 30 mins a piece. 😉
