Solved by BlackBox_. Go to Solution.
I don't think you can prevent a drafter from loading code he intends to load. You could track the loads and do random audits to find the employees that are not playing by the rules.
I also don't see how this has anything at all to do with Sarbanes-Oxley. It's about getting drawings done efficiently and accurately. Sarbanes-Oxley is about accurate and honest record keeping.
As a sole-proprietor, the first thing I did was to turn off SECURELOAD. IMO it adds nothing to the security of the system and is only a false promise of increased security. For instance, a reactor that could turn on/off SECURELOAD would make it self evident that it doesn't work.
I recently addressed a similar topic here, that may or may not be informative.
Even within a .NET event handler, one must wait until the Application.Idle (as an example), before one can successfully modify SECURELOAD (there may be an earlier event, but that was for demonstration only)... Even still, the code that was loaded, has already executed, malicious or not.
Also worthy of note, regarding SECURELOAD, you might consider this post.
Cheers
"How we think determines what we do, and what we do determines what we get."
In addition to what I (and Blackbox) already said:
1) A sysvar reactor cannot be used to change the variable that triggered it within that reactor's callback. (Basic reactor guidelines)
2) Even with SECURELOAD set to 2, a user could load a lisp program from another non-company, non-secure folder by using VLIDE.
3) A user could easily disable a functional sysvar reactor by using (vlr-remove-all) at the command line.
4) When posting code on this website use the code button on the posting editor or as txt attachment.
5) “It is impossible to make anything foolproof because fools are so ingenious.” source unknown
This is a solution (that demonstrates proper reactor technique only). It does not guarantee anything.
(vl-load-com) ;|Start a sysvar reactor to track and hold values of critical variables. Add the variable (all caps) and the preferred value of that variable as a dotted list to the data element of the reactor. Secureload is being monitored here. Expectations: This reactor can be disabled by a single (vlr-remove-all) by a knowledgable user. The secureload warning can be ignored by someone wanting to load certain programs. It is assumed that the user is using a (load "") form to load his programs and that a lispreactor would be sufficient to turn the variable back on. It may be necessary to add other reactors such as a command reactor to manage and hold variables other than secureload. I would suggest tracking the commandended, commandwillstart, and commandcancelled events for completeness for other variables.|; ;;D.C. Broad, Jr. APR 2014 (if (= (type svmon) 'VLR-SysVar-Reactor) nil (setq svmon (vlr-sysvar-reactor '(("SECURELOAD" . 2)) '((:vlr-sysvarchanged . checkvar)) ) ) ) (vlr-add svmon) (defun checkvar (r l) ;;;uncomment next line to see the reactor in action. ;;(alert "checkvar") (if (setq v (assoc (car l) (vlr-data r))) (progn (vlr-remove r) (vlr-lisp-reactor v '((:vlr-lispwillstart . resetvar))) ) ) ) (defun resetvar (r l) ;;(alert "resetvar") (vlr-remove r) (setvar (car (vlr-data r)) (cdr (vlr-data r))) (vlr-add svmon) )
@tommy.holder wrote:
dbroad, This Sarbanes-Oxley issue is stretching it a bit but is an IT requirement for maintaining complete and accurate records of code developed preventing shadow programming. Good idea on aduiting the users. May be more work than value but worth a look. As for the secure load, it does what it's planned to do. But in a company where loading priated code could cost the company and malicious code possiblities could affect the network this is a must. Especially if the boss says find a solution. So I am reaching for possible solutions. Thanks Tommy
You can mitigate risk, but especially if you're using AutoCAD 2012 or newer, you're unable to prevent potential malicious code. Period. The new Autoloader mechanism is implicitly trusted (which automagically bypasses any, and all measures you implement as part of your deployment, see the 'security' link in my siganture for more info), and worst, Autodesk considers the local disk (you know the one first possibly infected via infected folders, and has direct access to Al Gore's Interwebs) as being safer than files/folders on your own internal IT maintained network. Your best defense is a well organized deployment, and educated users.
FWIW - I'll offer you a comment I once offered Autodesk, regarding AutoCAD Security:
Coming from the Military myself, the security gamble isn’t about preventing exploitation of all possible vulnerabilities... It’s about securing your weakest points in critical order for mission accomplishment, controlling the flow of information, early warning system redundancy, and something that even the lowest ranking Soldier knows... Overlapping fields of fire.
Cheers
BlackBox_ , Thanks - I was wondering if you have tried to monitor the Registry for the change and change it back in the registry. But you comments on bundles puts the nail in the coffin so to speak. So there is not anyway to completely prevent this so I am done. At least until Autodesk offers a better solution. v/r/ Tommy
I missed this post, when I posted my latest comments....
Registry monitor is where I was headed next in concept, but I wanted to first explore other events within AutoCAD first (i.e., only make it as complex as needed)... All we're trying to do, is disallow LISP, etc. from being able to disable an otherwise 'secure' environment.
The crux of Autoloader, is that is doesn't adhere to AutoCAD security at all. Speaking both as a CAD Admin, and a published app developer, I'd hate to see users locked out of write permissions for these app-dependent folders simply on the basis that it is possible for malicious code to write a new .Bundle (given that Autoloader doesn't even bother to check to see if a given .Bundle is read-only, or hidden, etc., nor do users necessarily check what has/hasn't been added prior to launching AutoCAD).
Again, your best defense is educated users, and a reasonable early warning system (whatever that means in the context of your employers environment)... There are steps you can take, so I wouldn't write this off just yet, but I didn't want you to misunderstand the extent which you could pursue this specified task (and all those implied tasks) while managing your employer's expectations.
I'd still encourage you to to what you can, where you can, and continue to explore other means by which to entrench your deployment against potential risks as you see fit.
Cheers
Good Advice - thank you - Tommy
That is kind of you to say, Tommy; you're welcome.
Glad I was able to help. Training of your employees is the key to your security. As long as everyone cooperates, reactors can be an element in the protection but should only be used with the awareness of the weaknesses.
Blackbox - Your referenced posts and discussion was helpful as well. I didn't know about the built-in holes of the applicationplugins.
That is kind of you to say, dbroad; I'm happy to help.
Both Autoloader & Security are good at what they do individually, but there seems to be a bit of a 'left hand not talking to right hand' scenario in the finished result, IMO.
From a security standpoint, the ..\ApplicationPlugins\ folder(s) ultimately are unprotected and introduce potential risk (just as Acad.lsp did before it), and from a user/developer standpoint these folders are incredibly valuable for ease of app distribution and offer the promise of productivity gains through innovation... I think there's a middle ground to be had, I just don't think we're there yet.
AutoCAD Security is from the outset a process of evolution, that to be effective, inherently must walk the fine line between maintaining awareness & protection against potential threats, and must avoid any negative affect on user, or user's workflow in the process... At present, Autoloader & Security are mutually exclusive.
As a loosley related security example that predates all of this....
Something so simple as changing the order of operation for the mechanism that automagically loads Acad.[lsp[fas[vlx]]] and AcadDoc.[lsp[fas[vlx]]], such that either file located within SFSP (only if found), take precedence over that which may be found in DWGPREFIX, would have saved countless users literaly decades of Acad* file virus & worm exposure... Yet even with Autodesk staff in agreement (I may have mentioned it a time or two in the past), nothing has changed.
... My $0.02
Cheers
