Hi All,
I have a stupid quesiton. I just learned that you can run a lisp function in a lisp function entering (c:someLispFunction). This is useful but I was wondering if you can add preset key words for the getkword function. I tried to run overkill in this fashion but I can't figure out how to automat the user input sections of the routine. Is there a way to do this? If so please let me know and BTW you guru's on this forum rock!
Solved by p_mcknight. Go to Solution.
@vivifira wrote:
Hi All,
No questions are stupid. Young ones need to learn and old ones tend to forget.
Look into INITGET and it's flags.
Perhaps something like this?
(initget "Left Right Center")
(setq a (getkword "Enter justification [Left/Right/Center]<Center>: "))
(if (not a) (setq a "Center") );if
(cond
( (= a "Left") (princ) )
( (= a "Right") (princ) )
(T (princ) )
);cond
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
I think what the OP was asking for was how to use a lisp command as a lisp function without having to make it a lisp function. There are a couple of ways to do this. The most correct would be to use vlax-add-cmd to actually add your command to the built-in command set. Another somewhat simpler (albeit fairly hokey) method is to use vla-SendCommand. This basically writes a string to the command line in much the same way that a macro is done. Below is a basic set of commands that demonstrate how to do it. If you are farily new to lisp I would recommend starting with this method before going to the vlax-add-cmd method.
(defun c:test31 ( / val)
(initget 1)
(setq val (getint "\nSpecify number: "))
(alert (strcat "The specified number is " (itoa val) ". "))
(princ)
(defun c:test32 ( / )
;(c:test31)
(vla-SendCommand (vla-get-ActiveDocument (vlax-get-acad-object)) "test31 2 ")
(princ)
Overkill is already part of the built-in command set so you can just run it with the (command function. You will need to use the manual entry version to avoid dialogue boxes. If you already have a selection set of objects to run overkill on you can do
(command ".-overkill" ss "" "done") If you step through the command manually you will see how to add items to change the tolerance, ignore parts, and etc. For example
(command ".-overkill" ss "" "tolerance" 0.0001 "" "done")
I believe the express tools for 2011 include a lisp file called overkillsup.lsp which is a lisp function allowing programtic input of variables to run the function within other lisp routines. You might try that out.
An excerpt from the file is below
;; over-kill - delete overlaping and un-needed entities
;; Takes single list of arguments:
;; ss - selection set
;; fuz - for numeric comparisons
;; ignore - (optional) list of group codes specifying which common group codes to ignore
;; when comparing entities.
;; no-plines - (optional) flag - T means do NOT optimize segments within plines.
;; no-partial - (optional) flag - T means do NOT combine parallel segments that partially overlap
;; no-endtoend - (optional) flag - T means do NOT combine parallel segments that are end to end.
(defun acet-overkill2 ( alst / lst ss fuz ignore no-plines no-partial no-EndtoEnd
