Visual LISP, AutoLISP and General Customization
Running Lisp in Lisp
9 REPLIES 9
Message 1 of 10
vivifira
1067 Views, 9 Replies
Hi All,
I have a stupid quesiton. I just learned that you can run a lisp function in a lisp function entering (c:someLispFunction). This is useful but I was wondering if you can add preset key words for the getkword function. I tried to run overkill in this fashion but I can't figure out how to automat the user input sections of the routine. Is there a way to do this? If so please let me know and BTW you guru's on this forum rock!
9 REPLIES 9
Message 2 of 10
scot-65
in reply to: vivifira
@vivifira wrote:
Hi All,
No questions are stupid. Young ones need to learn and old ones tend to forget.
Look into INITGET and it's flags.
Perhaps something like this?
(initget "Left Right Center")
(setq a (getkword "Enter justification [Left/Right/Center]<Center>: "))
(if (not a) (setq a "Center") );if
(cond
 ( (= a "Left") (princ) )
 ( (= a "Right") (princ) )
 (T (princ) )
);cond
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 3 of 10
vivifira
in reply to: scot-65
Perhaps. I'll give this a try. Thanks.
Message 4 of 10
p_mcknight
I think what the OP was asking for was how to use a lisp command as a lisp function without having to make it a lisp function.  There are a couple of ways to do this.  The most correct would be to use vlax-add-cmd to actually add your command to the built-in command set.  Another somewhat simpler (albeit fairly hokey) method is to use vla-SendCommand.  This basically writes a string to the command line in much the same way that a macro is done.  Below is a basic set of commands that demonstrate how to do it.  If you are farily new to lisp I would recommend starting with this method before going to the vlax-add-cmd method.
(defun c:test31 ( / val)
  (initget 1)
  (setq val (getint "\nSpecify number: "))
  (alert (strcat "The specified number is " (itoa val) ". "))
  (princ)
(defun c:test32 ( / )
  ;(c:test31)
  (vla-SendCommand (vla-get-ActiveDocument (vlax-get-acad-object)) "test31 2 ")
  (princ)
Message 5 of 10
vivifira
in reply to: p_mcknight
I did not know about vla-sendCommand function. What I'm trying to do is add the effect of overkill to a lisp I'm trying to form, but I want to use predefined variables in the lisp so overkill runs in the background, no user input necessary. I would also like to do this without hacking a copyrighted lisp. Hench the delicate dance around to just run it in the lisp instead of chopping overkill up. Thanks guys for your help.
Message 6 of 10
p_mcknight
Overkill is already part of the built-in command set so you can just run it with the (command function.  You will need to use the manual entry version to avoid dialogue boxes.  If you already have a selection set of objects to run overkill on you can do
(command ".-overkill" ss "" "done")  If you step through the command manually you will see how to add items to change the tolerance, ignore parts, and etc.  For example
(command ".-overkill" ss "" "tolerance" 0.0001 "" "done")
Message 7 of 10
vivifira
I'm using CAD 2011 and overkill is still just a lisp routine in the express tools. So the .-overkill isn't recognized. I'm trying to work around this. Thanks for your help though.
Message 8 of 10
p_mcknight
I believe the express tools for 2011 include a lisp file called overkillsup.lsp which is a lisp function allowing programtic input of variables to run the function within other lisp routines.  You might try that out.
An excerpt from the file is below
;; over-kill - delete overlaping and un-needed entities
;; Takes single list of arguments:
;;  ss           - selection set
;;  fuz          - for numeric comparisons
;;  ignore       - (optional) list of group codes specifying which common group codes to ignore
;;                 when comparing entities.
;;  no-plines    - (optional) flag - T means do NOT optimize segments within plines.
;;  no-partial   - (optional) flag - T means do NOT combine parallel segments that partially overlap
;;  no-endtoend  - (optional) flag - T means do NOT combine parallel segments that are end to end.
(defun acet-overkill2 ( alst / lst ss fuz ignore no-plines no-partial no-EndtoEnd
Message 9 of 10
vivifira
Hmmm..... I'll look into this. Thanks. 🙂
Message 10 of 10
vivifira
Thanks a bunch! This is what I was looking for. I did a google search for overkillsup and it brought me to an older post that explained exactly what I was wanting to do. Here's the link for those who need it:
http://forums.autodesk.com/t5/AutoCAD-Express-Tools/How-do-I-call-Overkill-in-a-lisp-function/td-p/2...
Again Thanks A Bunch!
”Boost
