Run lisp from Vlisp editor
3 REPLIES 3
Wheelie22
463 Views, 3 Replies
In acad 2009 (at work) and my I acad 2002 (at home) i can select the lisp window and then load it into the currend acad session, than re-select the window and run it.
But in 2010 and 2012 (a w) the run option is not selectable, i can still (load"   ") and run the c: in the acad window but why not from the lisp editor so i can "Toggel break point" / "Add watch" "Last break" and check a few things.
This is with all lisp files !
3 REPLIES 3
Lee_Mac
in reply to: Wheelie22
Note that the controls on the Debug Toolbar are not to 'run' the program, but to control the evaluation after a break point has been set.
After loading code through the VLIDE Editor window, you still need to start the program using the "c:" syntax.
stevor
Sounds like your file has some statement to execute a function, like LeeMac implied, in order to run when loaded. The Visual Lisp editor, that file must be loaded, which shows as an edit window, then the 'Load active edit window' in the 'Tools' bar can be selected and executed, which loads the file. If the 'Console' is the active window,
S
Wheelie22
in reply to: stevor
1ste place a hold where you want to check
and run the c: in acad
”Boost
