I'm pretty new to autolisp and I have been trying to write some routines for a while but am constantly running into the same problem. I don't have visual lisp because I am on a mac and I test my routines by just copying them to the command line. It works most of the time but it seems that they just all of a sudden stop working, for example this routine was meant to add a corner to a duct and works fine:
(defun C:Corner()
(setq usersnap (getvar "osmode"))
(setq userorth (getvar "orthomode"))
(setvar "osmode" 129)
(setvar "orthomode" 0)
(setq a (getpoint "Select Outside Point"))
(setq b (getpoint "Select Inside Point"))
(setq dst1 (distance a b))
(setq ang1 (angle a b))
(setq mpt1 (polar a ang1 (/ dst1 2)))
(setvar "osmode" 130)
(setq dir (getpoint "Select Point Perpendicular to Midpoint"))
(setq dang (angle mpt1 dir))
(setvar "osmode" 0)
(setq outcor (polar a dang (* dst1 1.25)))
(setq incor (polar b dang (* dst1 0.25)))
(setq c (polar outcor ang1 (* dst1 1.25)))
(setq d (polar incor ang1 (* dst1 0.25)))
(command "line" a outcor c d incor b "")
However when I try to add on to it or change it at all, like by adding this which will be used later, it doesn't work
(defun C:Corner()
(setq vane (getstring "vanes y or n"))
(setvar "osmode" 0)
I get all sorts of errors, most of them just seem like its not interpreting correctly, like ill have (command "line" something...) and it will say unknown command "MMAND"
It happens with literally everything I write, is it something with copying and pasting to the command line? or Fraise?
Are you using an ASCII editor for your text? I know sometimes the " (quotation marks especially) can be a problem if they are not done in the right text editor. I'd check this first.
https://discussions.apple.com/message/5014223
I don't believe that's causing the problem, I'm using Fraise and from what I've read it is pretty basic text and should be working, also the codes seem to be failing at very random spots, not necessarily just around quotations. For example, it very often just cuts off words and says unknown command, later in the code it uses the variable vane21 and it spits out unknown command "ane21" It is spelled correctly in every instance.
If you save the ASCII files as .lsp and then load them using appload do they still error out?
