Rounding up block coordinates (insertion point)
3 REPLIES 3
1245 Views, 3 Replies
Maybe anyone has an idea on the following issue:
We have several AutoCAD drawings with hundreds of block references inserted with imprecise coordinates. Now we need to dimension all elements and need to correct these positions.
I am searching for a routine to round these positions up or down towards a 5mm precision so I don't have to manually move every single block element.
Is there any way to automate the task or do you know any workaround (like inserting the elements into a drawing with poorer unit precision settings)?
Thank you very much for your support!
Smiley Happy
3 REPLIES 3
Lee_Mac
Try the following simple program:
(defun c:roundins ( / e i m p s x )
    (if (null *tol*)
        (setq *tol* 5.0)
    (initget 6)
    (if (setq m (getreal (strcat "\nSpecify rounding tolerance <" (rtos *tol*) ">: ")))
        (setq *tol* m)
        (setq m *tol*)
    (if (setq s (ssget "_:L" '((0 . "INSERT"))))
        (repeat (setq i (sslength s))
            (setq e (entget (ssname s (setq i (1- i))))
                  p (assoc 10 e)
            (entmod (subst (cons 10 (mapcar '(lambda ( x ) (round x m)) (cdr p))) p e))
    (princ)
;; Doug Broad
(defun round ( value to )
    (setq to (abs to))
    (* to (fix (/ ((if (minusp value) - +) value (* to 0.5)) to)))
(princ)
in reply to: Lee_Mac
Brilliant!
Your script worked perfectly.
Thank you very much.
Smiley Wink
Lee_Mac
You're welcome Smiley Happy
Be sure to mark the post as the accepted solution so as to indicate that the thread is resolved Smiley Wink
”Boost
