That very issue came up before, and I wrote the attached. It lets you limit it to either plain Text or Mtext, or allow Both, and to choose whether to do all such entities in the drawing or let the User select the ones they want to rotate. It offers 180-degree rotation as the default, but you can specify any rotation you want.
Kent Cooper
Fatrobo wrote...
....I need to find a lisp that will rotate text 180 degrees about the insertion pioint (assuming I set the justification to MC) so the text doesn't move but rotates 180 degrees.
Kent Cooper, AIA
