• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Visual LISP, AutoLISP and General Customization
    Distinguished Contributor
    Rotating a table to current UCS
    113 Views, 1 Replies
    09-12-2012 11:50 AM
    Tables do no have a rotation angle. I can find the insert point, but there is no other point to make an angle calculation with.
    (setq objTable (vlax-ename->vla-object (car (entsel))))
    (vlax-dump-object objTable T)
    Please use plain text.
    Valued Contributor
    Re: Rotating a table to current UCS
    09-13-2012 02:34 AM in reply to: Redraiderr2009
    You may use vla-TransformBy with the UCS's transformation matrix.
    To get the UCS transformation matrix it mus be a NAMED UCS.
    This is a very simple example, it supposes your UCS is named previously:
    (defun align-table  (/ table mtrans)
      (setq table (vlax-ename->vla-object
                    (car (entsel "\nSelect Table:"))))
      (setq mtrans
             (vla-GetUCSMatrix
               (vla-get-ActiveUCS
                 (vla-get-activedocument (vlax-get-acad-object)))))
      (vla-TransformBy table mtrans))
    Reinaldo N. Togores
    AutoCAD Expert's Visual LISP
