Rotate3d command
6 REPLIES 6
Patchy
523 Views, 6 Replies
Rotate3d command
The command rotate3d asks for selecting objects and which axis is too lengthy.
How do I just select objects, pick a point, and rotate the items I selected on Y axis with rotation of example 60 degrees ?
Thank you for your help.
6 REPLIES 6
Kent1Cooper
in reply to: Patchy
One way would be to put this macro in a toolbar button or menu item somewhere:
^C^CSELECT \ROTATE3D P  Y \60
Kent Cooper, AIA
Patchy
in reply to: Patchy
Thank you Kent,
Can this be wrote in lisp?
(defun c:rty ( / )
(command "_rotate3d" pause .......... ??
Kent1Cooper
in reply to: Patchy
@Patchy wrote:
Thank you Kent,
(defun c:rty ( / )
(command "_.rotate3d" (ssget) "" "Y" pause "60")
Kent Cooper, AIA
Patchy
in reply to: Patchy
Beautiful.
Thank you Kent.
Kent1Cooper
in reply to: Patchy
@Patchy wrote:
Beautiful.
Thank you Kent.
You're welcome.  That seems so specific [Y axis only, 60 degrees only] that I wonder whether you might want different ones at times.  Rather than duplicate the whole line of code with different variables built in for each circumstance, you could do it as a function with arguments:
(defun r3 (ax rot)
  (command "_.rotate3d" (ssget) "" ax pause rot)
That could be the basis of any number of commonly-used combinations, making for shorter individual command definitions:
(defun C:r3y60 ()
  (r3 "Y" "60")
(defun C:r3x45 ()
  (r3 "X" "45")
(defun C:r3y90 ()
  (r3 "Y" "90")
(defun C:r3x-90 ()
  (r3 "Y" "-90")
and would also be available for use directly, for uncommon circumstances that don't deserve their own command definitions:
(r3 "Y" "22.5")
(r3 "X" "-15")
Kent Cooper, AIA
Patchy
in reply to: Patchy
I'm so fast now, i'm out of things to do
”Boost
