The command rotate3d asks for selecting objects and which axis is too lengthy.
How do I just select objects, pick a point, and rotate the items I selected on Y axis with rotation of example 60 degrees ?
Thank you for your help.
Solved by Kent1Cooper. Go to Solution.
@Patchy wrote:....
One way would be to put this macro in a toolbar button or menu item somewhere:
^C^CSELECT \ROTATE3D P Y \60
@Patchy wrote:Beautiful.
Thank you Kent.
You're welcome. That seems so specific [Y axis only, 60 degrees only] that I wonder whether you might want different ones at times. Rather than duplicate the whole line of code with different variables built in for each circumstance, you could do it as a function with arguments:
(defun r3 (ax rot)
(command "_.rotate3d" (ssget) "" ax pause rot)
That could be the basis of any number of commonly-used combinations, making for shorter individual command definitions:
(defun C:r3y60 ()
(r3 "Y" "60")
(defun C:r3x45 ()
(r3 "X" "45")
(defun C:r3y90 ()
(r3 "Y" "90")
(defun C:r3x-90 ()
(r3 "Y" "-90")
and would also be available for use directly, for uncommon circumstances that don't deserve their own command definitions:
(r3 "Y" "22.5")
(r3 "X" "-15")
