Hello all,
I have drawing with a lot of lines connect together like a "tree" and I need move the "branches" to right position (according my necessity). Today I use "rotate" command, but I spent much time to select a base point...
Is there a better way to do it?
Rotate using grip points?
thanks 🙂
Solved by Shneuph. Go to Solution.
left click on this grip.. select rotate.. then it will work..
You can also select the grip and hit enter twice to get into rotate mode.
EDIT:
Also, hit enter once to enter move mode.
