Rotate using grips...
3 REPLIES 3
464 Views, 3 Replies
Hello all,
I have drawing with a lot of lines connect together like a "tree" and I need move the "branches" to right position (according my necessity). Today I use "rotate" command, but I spent much time to select a base point...
Is there a better way to do it?
Rotate using grip points?
thanks 🙂
3 REPLIES 3
Shneuph
left click on this grip.. select rotate.. then it will work..
You can also select the grip and hit enter twice to get into rotate mode.
EDIT:
Also, hit enter once to enter move mode.
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
mid-awe
in reply to: Shneuph
Nice, and I thought I know most of the tricks. Well done Shneuph . 🙂
thank you Shneuph!! it was under my nose.
thanks a ton!
”Boost
