The following function will return a list of vertices for the selected
LWPolyline. You need to figure out WHICH 2 vertices your chosen point is
between and use them to define your angle. If and when I get a chance, I'll
see what I can come up with--unless someone else has something first. But
at least this can provide something to help get you started.
(defun GetPLVertices (ent / cnt ptlist)
(if (=(cdr(assoc 0 ent)) "LWPOLYLINE")
(progn(setq cnt 0)
(repeat (length ent)
(setq cnt (1+ cnt))
(if (= 10 (car (nth cnt ent)))
(if ptlist
(setq ptlist (append ptlist (list(nth cnt ent))))
(setq ptlist (list(nth cnt ent)))
ptlist)
;else - NOT LWPolyline!
(progn(Princ "\nERROR- This is NOT a valid element.")
(princ))
wrote in message news:4935082@discussion.autodesk.com...
I have an older lisp file (cirra 1993) that used to work up until the
advent of LWPOLYLINES. Now I need to know if I can modify this to use them.
It's supposed to rotate text to match the rotation of a line.
(princ "\nChange angle of TEXT to selected Line or Polyline")(princ)
(SETQ MARK 0)
(setq p1 (entget (car (nentsel "\nSelect text: "))))
(redraw (cdr (assoc -1 P1)) 3)
(setq P2 (nentsel "\nSelect Line: ")
P3 (entget (car P2)))
(cond ((= (cdr (assoc 0 P3)) "LINE")
(setq P6 (angle (cdr (assoc 10 P3)) (cdr (assoc 11 P3))))
((= (cdr (assoc 0 P3)) "VERTEX")
(setq P4 (cdr (assoc 10 P3))
P5 (osnap (cadr p2) "near")
P6 (angle P4 P5))
(if (and (< P6 4.7124)(> P6 1.5708)) (setq P6 (+ P6 3.1416)))
(entmod (subst (cons 50 P6) (assoc 50 P1) P1))
(SETQ ATOMLIST (CDR (MEMBER 'MARK ATOMLIST)))
(GC)(PRINC)
