Visual LISP, AutoLISP and General Customization
Rise Over Run Returns 0
3 REPLIES 3
kpennell
322 Views, 3 Replies
I'm prompting the user for a string to represent an angle.
(setq second_angle (getstring "\nWhat angle is the turned pipe sloping? "))
Then, depending on the slash location via:
(setq slashloc (vl-string-position (ascii "/") second_angle))
Getting the rise:
(setq rise (atoi (substr second_angle 1 slashloc)))
And the run:
(setq run (atoi (substr second_angle (+ 2 slashloc))))
Then do the rise/run calculation I get 0.0 returned:
(/ rise run)
So for a rise/run for 1/48, I should/want to have returned is the exact value that I can assign for later use, 1.193489424.
Stumped
KP
3 REPLIES 3
Ajilal.Vijayan
in reply to: kpennell
I think you need to Convert the string into a real number
use atof instead of atoi.
Kent1Cooper
When you divide an integer by an integer with the (/) function, you get an integer result.  At least one of them needs to be a real number instead.  Try using (atof) in place of (atoi).
Kent Cooper, AIA
stevor
To use your code anyway, add the 'real' then try:
  (/ rise run  1.0)
S
”Boost
