Visual LISP, AutoLISP and General Customization
Return name of different folders
8 REPLIES 8
Message 1 of 9
kpennell
366 Views, 8 Replies
Hello all,
The following gives me the first folder string, with no back-slashes, that the drawing exists in.
(setq FirstFolder
 ((lambda (/ tmpDir tmpPos)
 (substr
 (setq tmpDir (getvar "dwgprefix"))
 (+ 2 (setq tmpPos (vl-string-search "\\" tmpDir)))
 (- (vl-string-search "\\" tmpDir (1+ tmpPos)) (1+ tmpPos))))))
Is there a way to find the name of the second folder?
Is there a way to find the name of the third folder?
The string length of the characters for each of the first, second, third (and so on) folders are different, which means I can't count character using the "substr" function.
KP
8 REPLIES 8
Message 2 of 9
Kent1Cooper
in reply to: kpennell
@kpennell wrote:
Hello all,
One way is to use one of the many examples of string-splitting-up routines on this forum.  Just one example is the sdtol function [it stands for String Delimited to List] here.  If you apply it as in the first usage example there, you'll get a list from which you can easily extract any of the folder names using (cadr)/(caddr)/etc., or using (nth).
Kent Cooper, AIA
Message 3 of 9
kpennell
in reply to: Kent1Cooper
Hmm, I don't see that function in the help literature through AutoCAD.
I'll certainly be looking what I can see on this discussion group.
Thanks again KC
Message 4 of 9
alanjt_
(defun AT:Str2Lst (s d / i l d)
  ;; Convert string to list, based on separator
  ;; s - String to convert
  ;; d - Delimeter to break string into items
  ;; Ex. - (AT:Str2Lst "1,2,3" ",") -> '("1" "2" "3")
  ;; Alan J. Thompson, 11.11.09 / 04.01.10
  (while (setq i (vl-string-search (strcase d) (strcase s)))
    (setq l (cons (substr s 1 i) l)
          s (substr s (+ i 1 (strlen d)))
  (vl-remove "" (reverse (cons s l)))
eg.
(AT:Str2Lst (getvar 'DWGPREFIX) "\\")
Message 5 of 9
alanjt_
in reply to: alanjt_
Oops, if you want the third item in the list:
(caddr (AT:Str2Lst (getvar 'DWGPREFIX) "\\"))
Message 6 of 9
Kent1Cooper
No, you won't find it there -- I wrote it.  It's similar in many ways to others on the forum, but if I recall, many of the others work with single characters such as commas or spaces as delimiters [which is also viable in your situation, since as someone else pointed out, "\\" is really a single character in AutoLISP], but in (sdtol) I was going for the possibility of multiple-character delimiters, as you can see from the description there that uses "Mickey Mouse" as a delimiter.
Kent Cooper, AIA
Message 7 of 9
BlackBox_
eg.
Interesting approach... Here's one I just posted a bit ago... And another for FilePaths.
"How we think determines what we do, and what we do determines what we get."
Message 8 of 9
kpennell
KC,
Once again, I've accepted your response as the solution to my post.  Huge Thanks.  I can see this being very powerful for other applications.
KP
Message 9 of 9
Kent1Cooper
@kpennell wrote:
KC,
KP
Thank you -- it's good to know that routines written for a specific request are finding application to different [however slightly in this case] purposes.
Kent Cooper, AIA
”Boost
