- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Retrieving xdat from an entity
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hey Gang
How can i build a selection set of all circles and then retrieve the xdata attached to them? Thanks.
Southie
Re: Retrieving xdat from an entity
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
These sequences should give you some hints:
(regapp "myapp")
;Draw a test circle
(setq e (entlast));;Select circle
(entmod (list (cons -1 e) '(-3 ("myapp" (1000 . "this is xdata"))))) ;;add xdata to circle
(cdr (assoc -3 (entget e '("myapp")))) ;;get xdata from circle
(ssget '(0 . "circle"));;filtered selection set for circles.
(setq ss (ssget '((0 . "circle") (-3 ("myapp")))));;To filter for circles managed by "myapp".
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for the quick response. There use to be a Doug Broad who was a guru around here a while back.
Here is my attempt
(setq ss (ssget "x" '((0 . "circle") (-3 ("circ")))));;
(setq index 0)
(repeat (sslength ss)
(setq ent1 (entget (ssname ss index))
e (cdr (assoc -1 ent1))
xent (cdr (assoc -3 (entget e '("circ")))))
(setq index (+ index 1))
);repeat
xent = (("CIRC" (1002 . "{") (1000 . "qty 4") (1002 . "}"))) how do i assign "qty 4" to a variable. thanks.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
That's me.
There are ways to get the data but the most productive process is to play with the list functions: car, cdr, their composites: caar cadr cdar cddr, etc. and assoc. The person who wrot the app that stores the xdata is responsible for the ordering of the information in the xdata and should know how to extract an individual object. Some examples for your particular case using X as the variable name are:
_$(setq x '(("CIRC" (1002 . "{") (1000 . "qty 4") (1002 . "}"))))
_$ (car x)
_$ (caar x)
"CIRC"
_$ (cdr(car x))
((1002 . "{") (1000 . "qty 4") (1002 . "}"))
_$ (cdr(cdr(car x)))
((1000 . "qty 4") (1002 . "}"))
_$ (cdr(assoc 1000 (cdar x)))
"qty 4"
_$ (nth 1 (cdr(car x)) )
(1000 . "qty 4")
_$ (cdr(nth 1 (cdr(car x))))
"qty 4"
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Excellent! Thank you dbroad for your time and help.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Mr. dbroad if you get a chance
stumped on this. With e being a valid entityname the following works
(entmod (list (cons -1 e) '(-3 ("idnumqty" (1000 . "3")))))
however,
(setq xqty "3")
(entmod (list (cons -1 e) '(-3 ("idnumqty" (1000 . xqty)))))
does not work & get this error ; error: bad DXF group: (-3 ("idnumqty" (1000 . XQTY)))
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
southie wrote:Mr. dbroad if you get a chance
however,
(setq xqty "3")
with ' (quote) the line will be treated on its face value
(entmod (list (cons -1 e) (list -3 (list "idnumqty" (cons 1000 xqty)))))
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks dbroad & pb for all the help and sharing of your knowledge.
Southie
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You're welcome. Glad to help.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
southie wrote:Thanks dbroad & pb for all the help and sharing of your knowledge.
Southie
Good for you.
Cheers
