Reset Autocad 2006 settings like 2013
3 REPLIES 3
angiegauthier
975 Views, 3 Replies
We have a big issue where half our users can't open autocad. We have half running 2013 and half running 2006. For our 2013 users we've gone to our start menu and reset settings to default. and then just re-loaded our custom menus. How can I reset Autocad 2006 to default if I can't open Autocad?
I need help fast as we need to get people up and running.
thanks
Angie
3 REPLIES 3
Hi all,
So we are all up and running now, but I'd like to see if anyone knows why we have issues. It seems to happen when we run different versions of autocad. I wonder if when I create cui files (cuix files for those running 2013) if there is something I should be doing in a different way. What is the proper procedure to add customization when you have users running different autocad versions?
Angie
dgorsman
in reply to: angiegauthier
Between that many versions, its best to have separate files for each version.  With only a version or two separating them, and inside the same compatibility group e.g. 2010/11/12 sharing might be possible, and even practical.  Its a good idea to wipe the slate clean periodically to get new tools and work processes into play, and version updates are a good place to do this.
scot-65
Look into DefaultFormatForSave.
It is an setenv setting.
Ours is set to "24".
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
”Boost
