aqdam1978
Message 1 of 15 (764 Views)
Replacing substr(s) in a string variable
764 Views, 14 Replies
02-18-2013 11:11 AM
I write a code to replace strings in one string.
for example
str="AutoDesk, AutoCAD, 2013, Electrical, 64Bit"
patt=", "
NewStr=" - "
==> result: "AutoDesk - AutoCAD - 2013 - Electrical - 64Bit"
;;replaces NewStr instead of Patt(s) in Str string
(defun ReplaceStr (NewStr Patt Str)
(While (> (vl-string-search ptt str) 0)
	(setq Str (vl-string-subst NewStr patt Str))
);;while
str
; usage
;(ReplaceStr " - " ", " "AutoDesk, AutoCAD, 2013, Electrical, 64Bit")
==> result= ; error: bad argument type: (or stringp symbolp): nil
What is my mistake(s)?
Valued Contributor
Rtogores
Message 2 of 15 (753 Views)
Re: Replacing substr(s) in a string variable
02-18-2013 12:25 PM in reply to: aqdam1978
A similar function that works is included in Chapter 5 (Listing 5.12) of my book on AutoLISP/Visual LISP.
This is the code:
(defun replace (new old string)
  (while (vl-string-search old string)
    (setq string (vl-string-subst new old string))
  ) ;_ end of  while
) ;_ end of  defun
;;;Listing 5.12. Replacement of characters in a string.
But, if you only want to replace the "," with a  "-" without including a space before the dash you can use:
_$ (vl-string-translate "," "-" "AutoDesk, AutoCAD, 2013, Electrical, 64Bit")
"AutoDesk- AutoCAD- 2013- Electrical- 64Bit"
_$
More info in my blog lispexpert.blogspot.com.
aqdam1978
Message 3 of 15 (749 Views)
02-18-2013 12:31 PM in reply to: Rtogores
Thank you for your answer, But what was my mistake? why my lisp did not work?
hmsilva
Message 4 of 15 (744 Views)
02-18-2013 12:37 PM in reply to: aqdam1978
aqdam,
your code works, just miss an "a" in the second "patt"
(While (> (vl-string-search patt str) 0)
);;while
str
; usage
Henrique
Valued Contributor
Rtogores
Message 5 of 15 (734 Views)
02-18-2013 12:45 PM in reply to: aqdam1978
Yes, only a typo, ptt for patt.
But the point is that the function can be simplified, as vl-string-search will return nil when no further ocurrences are found, and the value returned by the last setq will be the value returned by the function.
aqdam1978
Message 6 of 15 (731 Views)
02-18-2013 12:50 PM in reply to: Rtogores
aaaah, yes,
	(While (vl-string-search patt str)
	);;while
aqdam1978
Message 7 of 15 (700 Views)
02-19-2013 05:28 PM in reply to: hmsilva
I have a problem with this code:
	);;while
str ;;in case of no patt exist in str, just return str itself
 as you know in prompt command we have:
(prompt "c:\\") (princ) ==> c:\
(prompt "c:\\\\")(princ) ==> c:\\
so, why this code does not work and AutoCAD goes to "no response" situation?
(prompt (ReplaceStr "\\\\" "\\" "c:\\"))(princ)  ;;AutoCAD will be freeze!
pbejse
Message 8 of 15 (692 Views)
02-19-2013 08:03 PM in reply to: aqdam1978
Because of an endless loop aqdam1978  (vl-string-search patt str) will never evaluate to nil
Try this instead  using vl-string-subst to do a find and replace in external file by AlessiMarc'Antonio
HTH
Valued Contributor
Rtogores
Message 9 of 15 (674 Views)
02-20-2013 02:49 AM in reply to: aqdam1978
In this case you are just adding the same character to the string, not replacing it with a different one, so vl-string-search will always find that character and add a couple of new occurrences in each loop, so it'll never conclude.
To catch these kind of error I would suggest you set a breakpoint in your code and open a watch window to inspect the *LAST-VALUE*. Then call the function in the VLISP Editor and use the Step Into button to evaluate each expression. For a video explaining this way to inspect a program's workings, you can see Module 5 of my AU class: http://au.autodesk.com/?nd=class&session_id=10671.
In this case you do not need your replacement function.(vl-string-subst "\\\\" "\\" "C:\\") will do.
Valued Contributor
Rtogores
Message 10 of 15 (666 Views)
02-20-2013 04:01 AM in reply to: Rtogores
Rtogores wrote: For a video explaining this way to inspect a program's workings, you can see Module 5 of my AU class: http://au.autodesk.com/?nd=class&session_id=10671.
Also (better) in Module 3!
You are not logged in.
Ask the Community
