Visual LISP, AutoLISP and General Customization
Active Contributor
andit
Message 1 of 8 (485 Views)
Repeating Break at Single Point
485 Views, 7 Replies
11-07-2011 04:06 PM
Hi All,
I'm creating the following macro:- (defun C:BK () (command "_BREAK" PAUSE "_F" PAUSE "@" )(princ)) to add to a shortcut key lisp file and then I want it to repeat... How do I make it repeat?
I want it to do the same as this:- *^C^C_break \_f \@ but as a shortcut key in a lisp format.
Cheers,
Andy
*Expert Elite*
Kent1Cooper
Message 2 of 8 (478 Views)
Re: Repeating Break at Single Point
11-07-2011 06:37 PM in reply to: andit
One simple way:
(defun C:BK ()
  (while T
    (command "_BREAK" PAUSE "_F" PAUSE "@")
You could add error handling so you wouldn't see the "error: Function cancelled" message when you hit Escape to stop it.
Kent Cooper
Active Contributor
andit
Message 3 of 8 (472 Views)
11-07-2011 08:57 PM in reply to: Kent1Cooper
Thankyou Kent that what I was looking for, may I ask how the "(while T" works to repeat the command?
Cheers,
Andy
*Expert Elite*
Lee_Mac
Message 4 of 8 (462 Views)
11-08-2011 03:40 AM in reply to: Kent1Cooper
Kent1Cooper wrote:
One simple way:
Or:
(defun c:bk nil
    (while (vl-cmdf "_.break" pause "_F" pause "@")) (princ)
(vl-load-com)
So that no error handler is required.
Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
Expert Elite
With Mathematics there is the possibility of perfect rigour, so why settle for less?
*Expert Elite*
Kent1Cooper
Message 5 of 8 (454 Views)
11-08-2011 05:02 AM in reply to: andit
See (while) in the AutoLISP Reference.  As long as the 'testexpr' argument doesn't evaluate to nil, it keeps doing what is asked for after that.  T is the symbol for True, and never evaluates to nil [unless you commit the crime of using it for a variable name and overriding that].  It could be anything that doesn't, such as
(while 1 (command ....
Kent Cooper
stevor
Message 6 of 8 (452 Views)
11-08-2011 05:03 AM in reply to: andit
Also, you can use one GETPOINT, with or without object snaps, to assign both of the break points.
S
*Expert Elite*
Kent1Cooper
Message 7 of 8 (449 Views)
11-08-2011 05:11 AM in reply to: Lee_Mac
Lee_Mac wrote:
Or:
I don't think it would have occurred to me to use a (while) function without any what-to-do-then expression(s) after the test expression, but sure enough, they are optional.
Kent Cooper
Valued Mentor
alanjt_
Message 8 of 8 (442 Views)
11-08-2011 06:04 AM in reply to: Kent1Cooper
I've been using this for quite some time, you could just replace the if with while...
(defun c:BA (/ e p)
  ;; Break Object @ Point
  ;; Alan J. Thompson, 03.26.09 / 08.23.10
  (setvar 'errno 0)
  (if (while (and (not e) (/= 52 (getvar 'errno))) (setq e (entsel "\nSelect object to break: ")))
    (progn (setq p (cond ((getpoint "\nSpecify point to break @ <Selection Point>: "))
                         ((osnap (cadr e) "_near"))
           (vl-cmdf "_.break" e "_F" "_non" p "_non" p)
  (princ)
You are not logged in.
Announcements
Need installation help?
Ask the Community
