Repeating Break at Single Point
10 REPLIES 10
Message 1 of 11
andit
2619 Views, 10 Replies
Hi All,
I'm creating the following macro:- (defun C:BK () (command "_BREAK" PAUSE "_F" PAUSE "@" )(princ)) to add to a shortcut key lisp file and then I want it to repeat... How do I make it repeat?
I want it to do the same as this:- *^C^C_break \_f \@ but as a shortcut key in a lisp format.
Cheers,
Andy
10 REPLIES 10
Message 2 of 11
Kent1Cooper
in reply to: andit
One simple way:
(defun C:BK ()
  (while T
    (command "_BREAK" PAUSE "_F" PAUSE "@")
You could add error handling so you wouldn't see the "error: Function cancelled" message when you hit Escape to stop it.
Kent Cooper, AIA
Message 3 of 11
andit
in reply to: Kent1Cooper
Thankyou Kent that what I was looking for, may I ask how the "(while T" works to repeat the command?
Cheers,
Andy
Message 4 of 11
Lee_Mac
@Kent1Cooper wrote:
One simple way:
Or:
(defun c:bk nil
    (while (vl-cmdf "_.break" pause "_F" pause "@")) (princ)
(vl-load-com)
So that no error handler is required.
Message 5 of 11
Kent1Cooper
in reply to: andit
See (while) in the AutoLISP Reference.  As long as the 'testexpr' argument doesn't evaluate to nil, it keeps doing what is asked for after that.  T is the symbol for True, and never evaluates to nil [unless you commit the crime of using it for a variable name and overriding that].  It could be anything that doesn't, such as
(while 1 (command ....
Kent Cooper, AIA
Message 6 of 11
stevor
in reply to: andit
Also, you can use one GETPOINT, with or without object snaps, to assign both of the break points.
S
Message 7 of 11
Kent1Cooper
in reply to: Lee_Mac
@Lee_Mac wrote:
Or:
I don't think it would have occurred to me to use a (while) function without any what-to-do-then expression(s) after the test expression, but sure enough, they are optional.
Kent Cooper, AIA
Message 8 of 11
alanjt_
I've been using this for quite some time, you could just replace the if with while...
(defun c:BA (/ e p)
  ;; Break Object @ Point
  ;; Alan J. Thompson, 03.26.09 / 08.23.10
  (setvar 'errno 0)
  (if (while (and (not e) (/= 52 (getvar 'errno))) (setq e (entsel "\nSelect object to break: ")))
    (progn (setq p (cond ((getpoint "\nSpecify point to break @ <Selection Point>: "))
                         ((osnap (cadr e) "_near"))
           (vl-cmdf "_.break" e "_F" "_non" p "_non" p)
  (princ)
Message 9 of 11
 Hi, your lisp has been pretty useful for me but, How do you stop it? it seems like I am in an infinite loop I can't get out of.
Message 10 of 11
solved, just escape a lot of times.
Message 11 of 11
john.uhden
in reply to: alanjt_
I like your use of "errno."  But your selection may be an unbreakable object such as text.
Here's a version I wrote a while back.  It presumes that anything that is offsetable can be broken...
(defun C:BreakAt ( / *error* cmdecho E Obj P)
;; Created (12-05-06) by John F. Uhden
  (or *acad* (setq *acad* (vlax-get-acad-object)))
  (or *doc* (setq *doc* (vla-get-ActiveDocument *acad*)))
  (defun *error* (error)
    (if (= (type cmdecho) 'INT)(setvar "cmdecho" cmdecho))
    (sssetfirst)
    (vla-endundomark *doc*)
    (cond
      ((not error))
      ((wcmatch (strcase error) "*QUIT*,*CANCEL*"))
      (1 (princ (strcat "\nERROR: " error)))
    (princ)
  (vla-startundomark *doc*)
  (setq cmdecho (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (command "_.expert" (getvar "expert"))
  (and
    (setq E (car (entsel "\nPick object to break: ")))
    (sssetfirst nil (ssadd E))
    (setq Obj (vlax-ename->vla-object E))
    (or
      (vlax-method-applicable-p Obj 'Offset)
      (prompt "\nCan not break this object")
    (setq P (getpoint "\nSelect break point: "))
    (setq P (vlax-curve-getclosestpointto Obj P))
    (command "_.break" E P "@")
  (*error* nil)
(defun c:BA ()(C:BreakAt))
John F. Uhden
”Boost
