I have multiple floor plans in a drawing one of which I need to explode 3-4 times to change the lineweight to 9mm. I have tried to put something that will repeat explode but I am having problems with plines within the blocks not exploding.
(defun c:tmp (ss)
(setq ss (ssget))
(setvar 'qaflags 1)
(repeat 3 (vl-cmdf "._explode" ss ""))
(setvar 'qaflags 0)
(vl-cmdf "chprop" ss "" "lw" "0.09" "")
Solved by hmsilva. Go to Solution.
@smaher12 wrote:I have multiple floor plans in a drawing one of which I need to explode 3-4 times to change the lineweight to 9mm. I have tried to put something that will repeat explode but I am having problems with plines within the blocks not exploding.
(defun c:tmp (ss)
(setq ss (ssget))
(setvar 'qaflags 1)
(setvar 'qaflags 0)
(vl-cmdf "chprop" ss "" "lw" "0.09" ""))
That's probably because after the first Explode, 'ss' is no longer there. But since the results of an Explode get categorized as the Previous selection, you should be able to do something like this [untested]:
(setvar 'qaflags 1)
(repeat 2 (vl-cmdf "._explode" "_p" ""))
(setvar 'qaflags 0)
smaher12,
a different approach,
(defun c:test (/ ss old-echo item ss1 item1) (setq old-echo (getvar "CMDECHO")) (setvar "CMDECHO" 0) (if (setq ss (ssget '((0 . "INSERT")))) (foreach item (mapcar 'cadr (ssnamex ss)) (vl-cmdf "Explode" item) (while (setq ss1 (ssget "_P" '((0 . "INSERT")))) (foreach item1 (mapcar 'cadr (ssnamex ss1)) (vl-cmdf "Explode" item1) (if (setq ss (ssget "_P" '((0 . "LWPOLYLINE")))) (vl-cmdf "chprop" ss "" "lw" "0.09" "") ) ) ) ) ) (setvar "CMDECHO" old-echo) (princ) )
Hope that helps
Henrique
Problem with that approach is you may inaverdently "explode" other exploadable objects .e.g. Annotative objects, Mtext and such.
You may have to add a filter with "_P"
(ssget "_P" '((0 . "INSERT,*LINE")))
(setq ss (ssget)) (vl-cmdf "._explode" ss "") (while (setq ss (ssget "_P" '((0 . "INSERT,LWPOLYLINE")))) (vl-cmdf "._explode" ss ""))
devitg,
Example drawing attached.
hmsilva,
For whatever reason your code crashes my AutoCAD.
Kent1Cooper & pbejse,
I have tried your suggestions with the following and now I am have some troubles with changing the lineweights to 0.09mm.
(defun c:test () (vl-cmdf "LAYER" "F" "S-ANNO-TEXT" "") (setq ss (ssget)) (setvar 'qaflags 1) (vl-cmdf "._explode" ss "") (vl-cmdf "CHPROP" "_p" "" "LW" "0.09" "") (while (setq ss (ssget "_P" '((0 . "INSERT,LWPOLYLINE")))) (vl-cmdf "._explode" ss "") (vl-cmdf "CHPROP" SS "" "LW" "0.09" "")) (setvar 'qaflags 0) (vl-cmdf "LAYER" "T" "S-ANNO-TEXT" "") )
smaher12
revised code
(defun c:test (/ ss old-echo item ss1 item1) (setq old-echo (getvar "CMDECHO")) (setvar "CMDECHO" 0) (if (setq ss (ssget '((0 . "INSERT")))) (progn (foreach item (mapcar 'cadr (ssnamex ss)) (command "Explode" item) (while (setq ss1 (ssget "_P" '((0 . "INSERT")))) (foreach item1 (mapcar 'cadr (ssnamex ss1)) (command "Explode" item1) ) ) (if (setq ss (ssget "_P" '((0 . "LWPOLYLINE"))));if all previus, remove list (command "chprop" ss "" "lw" "0.09" "") ) ) ) ) (setvar "CMDECHO" old-echo) (princ) )
I understood that you only wanted to modify the "lw" in the lwpolylines, if you want to change all entities, just remove the last filter list
Henrique
I was thinking working like the following. Except I only want to select the plan one time, explode everything (mlines, plines, and blocks) until it's just lines and change all of it's lineweights to 0.09.
(defun c:test () (vl-cmdf "layer" "F" "S-ANNO-TEXT" "") (setq ss (ssget)) (setvar 'qaflags 1) (vl-cmdf "._explode" "ss" "") (while (setq ss (ssget "_P" '((0 . "INSERT,LWPOLYLINE")))) (vl-cmdf "._explode" ss "")) (setvar 'qaflags 0) (setq ss1 (ssget)) (vl-cmdf "chprop" ss1 "" "lw" "0.09" "") (vl-cmdf "layer" "T" "S-ANNO-TEXT" "") )
smaher12
sorry I responded too quickly, after seeing your code, I realized that you want to explode everything that is possible
and applying a lineweight of 0.09 to all objects.
I think this code does what you seek
(defun c:test (/ ss old-echo item ss1 item1 ss2) (setq old-echo (getvar "CMDECHO")) (setvar "CMDECHO" 0) (command "LAYER" "F" "S-ANNO-TEXT" "") (if (setq ss (ssget)) (progn (command "chprop" ss "" "lw" "0.09" "") (if (setq ss1 (ssget "_P" '((0 . "INSERT,*POLYLINE,MLINE")))) (foreach item (mapcar 'cadr (ssnamex ss1)) (command "Explode" item) (while (setq ss2 (ssget "_P" '((0 . "INSERT,*POLYLINE;MLINE")))) (foreach item1 (mapcar 'cadr (ssnamex ss2)) (command "Explode" item1) ) ) (if (setq ss (ssget "_P")) (command "chprop" ss "" "lw" "0.09" "") ) ) ) ) ) (command "LAYER" "T" "S-ANNO-TEXT" "") (setvar "CMDECHO" old-echo) (princ) )
EDITED
added MLINE
all types of polylines *POLYLINES
Henrique
Please find attached the dwg , as I understand what do you want to do.
smaher12
there was a typo in my last code, *POLYLINE;MLINE, try this
(defun c:test (/ ss old-echo item ss1 item1 ss2) (setq old-echo (getvar "CMDECHO")) (setvar "CMDECHO" 0) (command "LAYER" "F" "S-ANNO-TEXT" "") (if (setq ss (ssget)) (progn (command "chprop" ss "" "lw" "0.09" "") (if (setq ss1 (ssget "_P" '((0 . "INSERT,*POLYLINE,MLINE")))) (foreach item (mapcar 'cadr (ssnamex ss1)) (command "Explode" item) (while (setq ss2 (ssget "_P" '((0 . "INSERT,*POLYLINE,MLINE")))) (foreach item1 (mapcar 'cadr (ssnamex ss2)) (command "Explode" item1) ) ) (if (setq ss (ssget "_P")) (command "chprop" ss "" "lw" "0.09" "") ) ) ) ) ) (command "LAYER" "T" "S-ANNO-TEXT" "") (setvar "CMDECHO" old-echo) (princ) )
Henrique
smaher12 , here is the lisp I use, with your sample , I have nothing to guess
(defun c:change-lw-in-blk () (vl-load-com) (setq blk-ss (ssget "x" '( ( 0 . "INSERT"))));_add filter as need (setq blk-obj-act-ss (vla-get-ActiveSelectionSet adoc)) (vlax-for blk-obj blk-obj-act-ss (if (vlax-property-available-p blk-obj 'LINEWEIGHT t) (VLA-PUT-LINEWEIGHT blk-obj acLnWt009);_change weight as need ) ) ;| acLnWtByLayer acLnWtByBlock acLnWtByLwDefault acLnWt000 acLnWt005 acLnWt009 acLnWt013 acLnWt015 acLnWt018 acLnWt020 acLnWt025 acLnWt030 acLnWt035 acLnWt040 acLnWt050 acLnWt053 acLnWt060 acLnWt070 acLnWt080 acLnWt090 acLnWt100 acLnWt106 acLnWt120 acLnWt140 acLnWt158 acLnWt200 acLnWt211 |; );_ end main defun
smaher12,
tested with your dwg, and works as expected.
(defun c:test (/ ss old-echo item ss1 item1 ss2) (setq old-echo (getvar "CMDECHO")) (setvar "CMDECHO" 0) (command "LAYER" "F" "S-ANNO-TEXT" "") (if (setq ss (ssget)) (progn (command "chprop" ss "" "lw" "0.09" "") (if (setq ss1 (ssget "_P" '((0 . "INSERT,*POLYLINE,MLINE")))) (foreach item (mapcar 'cadr (ssnamex ss1)) (command "Explode" item) (if (setq ss (ssget "_P")) (command "chprop" ss "" "lw" "0.09" "") ) (while (setq ss2 (ssget "_P" '((0 . "INSERT,*POLYLINE,MLINE")))) (foreach item1 (mapcar 'cadr (ssnamex ss2)) (command "Explode" item1) ) ) (if (setq ss (ssget "_P")) (command "chprop" ss "" "lw" "0.09" "") ) ) ) ) ) (command "LAYER" "T" "S-ANNO-TEXT" "") (setvar "CMDECHO" old-echo) (princ) )
Henrique
hmsila,
Fantastic! Thank you very much. I was playing around with your code last night. I only made a minor tweek and added a filter to the initial ssget. I found that the filter worked better than freezeing or locking the text layer with blocks that contained text. The only buggy thing I found was if you have a block that was created multiple blocks. Not really a problem for me as I only have one block that is created with multiple blocks. I will simply redefine the block.
Now that I have a little better understanding of how filters work. As I look at the filter, something is already telling me instead of listing ("INSERT,LINE,*POLYLINE,MLINE,SPLINE etc...) why not include everything and just exclude TEXT,MTEXT. Something like if not a member "text" "mtext". What do you think?
(defun c:test (/ ss old-echo item ss1 item1 ss2) (setq old-echo (getvar "CMDECHO")) (setvar "CMDECHO" 0) (if (setq ss (ssget '((0 . "INSERT,LINE,*POLYLINE,MLINE,SPLINE,ARC,CIRCLE")))) (progn (command "chprop" ss "" "lw" "0.09" "") (if (setq ss1 (ssget "_P" '((0 . "INSERT")))) (foreach item (mapcar 'cadr (ssnamex ss1)) (command "Explode" item) (if (setq ss (ssget "_P")) (command "chprop" ss "" "lw" "0.09" "") ) (while (setq ss2 (ssget "_P" '((0 . "INSERT")))) (foreach item1 (mapcar 'cadr (ssnamex ss2)) (command "Explode" item1) ) ) (if (setq ss (ssget "_P")) (command "chprop" ss "" "lw" "0.09" "") ) ) ) ) ) (setvar "CMDECHO" old-echo) (princ) )
you think?
You're welcome, smaher12
glad you got a solution, to not select TEXT and MTEXT, change
(if (setq ss (ssget '((0 . "INSERT,LINE,*POLYLINE,MLINE,SPLINE,ARC,CIRCLE")))) ;; to (if (setq ss (ssget '((0 . "~*TEXT"))))
Hope that helps, good luck
Henrique
Henrique, Perfect!
~ (bitwise NOT) I have to pick up and read my release 13 Customization Guide more often. The days when you recieved a book(s) with AutoCAD. 🙂 Thanks again!
smaher12 wrote:
Do you know how I can incorporate this in somehow?
incorporate into the above solution will be difficult, because using the command erase, we will lose part of the selection that does not belong to the S-FL-TILE layer, and we need to continuing to explode.
I have to think of a different approach...
Henrique
maybe something like
(defun c:test (/ ss old-echo item ss1 item1 ss2 ss3) (setq old-echo (getvar "CMDECHO")) (setvar "CMDECHO" 0) (if (setq ss (ssget '((0 . "~*TEXT")))) (progn (if (setq ss3 (ssget "_P" '((8 . "S-FL-TILE")))) (progn (command "select" ss "_r" ss3 "") (setq ss nil) (setq ss (ssget "_P")) (command "erase" ss3 "") ) ) (command "chprop" ss "" "lw" "0.09" "") (if (setq ss1 (ssget "_P" '((0 . "INSERT,*POLYLINE,MLINE")))) (foreach item (mapcar 'cadr (ssnamex ss1)) (command "Explode" item) (if (setq ss (ssget "_P")) (command "chprop" ss "" "lw" "0.09" "") ) (while (setq ss2 (ssget "_P" '((0 . "INSERT,*POLYLINE,MLINE")))) (foreach item1 (mapcar 'cadr (ssnamex ss2)) (command "Explode" item1) ) ) (if (setq ss (ssget "_P")) (command "chprop" ss "" "lw" "0.09" "") ) ) ) ) ) (setvar "CMDECHO" old-echo) (princ) )
I think that is what you want, try it, is minimally tested...
hope that helps
Henrique
