By the way, did you go to the right discussion group?
It is dated back to 29 Sept 2001
You can do a search by doing this: / click find icon / find dialog box open
up / make sure the 'Look In' field
direct to 'autodesk.autocad.2000general' / in the 'From' name field type
either 'Danny' or 'Dave' / click ' New Search'
This will search the specified discussion group for topics related to
'Danny' or 'Dave'
You also can search for the 'Subject' field which is 'object property
toolbar'
Anyway this is what I've got from Dave.
Danny,
It would be much easier to just load a small partial menu using MENULOAD
containing an altered OBJ PROP toolbar definition. Like this:
***MENUGROUP=MYPARTIALMENU
***TOOLBARS
**TB_OBJECT_PROPERTIES
ID_TbObjectP [_Toolbar("Object Properties", _Top, _Show, 0, 1, 1)]
ID_Ai_molc [_Button("Make Object's Layer Current", "ICON_16_MOLC",
"ICON_16_MOLC")]^C^C_ai_molc
ID_Layer [_Button("Layers", "ICON_16_LAYERS",
"ICON_16_LAYERS")]'_layer
[_Control(_Layer)]
ID_LayerP [_Button("Layer Previous", "ICON_16_LAYERP",
"ICON_16_LAYERP")]^C^C_LayerP
(watch the word wrap, every line should start with ID)
Just copy/paste this to a text editor and save as MYPARTIALMENU.mns and put
it in a custom folder which you have added to your acad search path. This
eliminates fiddling with the standard acad menus, keeping backup copies,
etc. You can then just turn off the acad standard OBJ PROP toolbar and turn
on the customized toolbar with View/Toolbars and pick the appropriate menu
in the Menu Groups dropdown on the Toolbar tab. If you want to customize
more of your toolbars, drop down menus etc you would use this or another
partial menu instead of altering the standard acad menus as the time saved
in re-installs and upgrading is well worth the small amount of time to
prepare the partial menus. My motto is "Never Fiddle With Standard Acad
Files!" (no offense meant to Tim's advise though)
Dave
"danny" wrote in message
news:0BD128C0A15CF6D37841625AAECFA002@in.WebX.maYIadrTaRb...
> Thanks Tim,
> Can I reinstate to the original once I edit it?
> "Tim Skene" wrote in message
> news:65A75C834A654A017326D47333330C29@in.WebX.maYIadrTaRb...
> > Edit the ACAD.MNS file and in the toolbars section remove the following
> > items from the Object Properties toolbar:
> > ID_CtrlColor [_Control(_Color)]
> > ID_CtrlLinet [_Control(_Linetype)]
> > ID_CtrlLineW [_Control(_Lineweight)]
> > ID_CtrlPStyl [_Control(_PlotStyle)]
> > The product below has a wide toolbar like the Standard toolbar but with
> the
> > layer drop-down list, and also all the drop-downs as separate toolbars,
if
> > you want to see how to do it.
> > Tim Skene
> > PRO Menu - The Productivity Toolbox for AutoCAD
> > www.multicim.com/pmenu.html
danny
"Rob Starz" wrote in message
news:25F22E85099AD94844E354D474042EE1@in.WebX.maYIadrTaRb...
> I searched the 2000 NG and found nothing under Object Property Toolbar.
> Rob Starz
> Stardsign cad solutions
> iC - AEC Information Center
> www.stardsign.com/aecic.html
> LayerX beta testers needed... www.stardsign.com/beta_programs.htm
