Hi all,
I have a drawing with DXE files in xrefs. I am not able to remove these references. How to Remove the DXE files from Xref.
Thavasi
thavasi1982,
take a look in this thread in forums.augi.com, irneb, posted a lisp that removes the DXE files, and more.
hope that helps
Henrique
I have used irneb's utility also. It is a handy tool and allows you to select the DXE you want to delete.
I have had some issues with it causing Autocad to stop responding. So make sure you save your work before using it.
