Member
ericwhitmore
Message 1 of 8 (370 Views)
Quick block
370 Views, 7 Replies
05-11-2012 09:06 AM
I have migrated o a new office and I am looking for a Lisp routine that used to make Blocks in-place instantly.  he name of the block doesn't matter, but it can't be an anonymous block (I already have that routine!)
Does anyone have this lisp routine they could share?  Basically, you run the Lisp command, select whatever you want and it instantly transforms your selection into a randomly named block.  I think I got this routine off of a Hot Tip Harry website a LONG time ago.
HELP!
Distinguished Mentor
_Tharwat
Message 2 of 8 (366 Views)
Re: Quick block
05-11-2012 09:32 AM in reply to: ericwhitmore
Things like this .... ?
(defun c:Test (/ selectionset insertionpoint number Blockname)
  ;;; Tharwat 11. May. 2012 ;;
  (if (and (setq selectionset (ssget "_:L"))
           (setq insertionpoint (getpoint "\n Specify insertion point :"))
    (progn
      (setq number    1
            Blockname (strcat "MyBlock" (itoa number))
      (while (tblsearch "BLOCK" Blockname)
        (setq Blockname
               (strcat "MyBlock" (itoa (setq number (1+ number))))
      (command "_.-Block" Blockname insertionpoint selectionset ""
    (princ)
  (princ)
____________________________________________________
Get learn and learn and practice , to become experienced guy .
Member
ericwhitmore
Message 3 of 8 (364 Views)
Re: Quick block
05-11-2012 09:37 AM in reply to: _Tharwat
Almost!  I ran this lisp and it deletes the original content, but I just want to convert a selection to a named block, in place, without having to reinsert it.
THANK YOU FOR YOUR HELP!
_Tharwat
Message 4 of 8 (360 Views)
Re: Quick block
05-11-2012 09:43 AM in reply to: ericwhitmore
With the adds of command call insert , we will re-insert the same block name in its chosen insertion point . :smileyvery-happy:
Try and tell me back ..
    (progn
      (setq number    1
        (setq Blockname
      (command "_.-Block" Blockname insertionpoint selectionset "")
      (command "_.-insert" Blockname insertionpoint "" "" "")
    (princ)
  (princ)
Member
ericwhitmore
Message 5 of 8 (353 Views)
Re: Quick block
05-11-2012 09:57 AM in reply to: _Tharwat
Perfect!!!  Way to go!
Kent1Cooper
Message 6 of 8 (351 Views)
Re: Quick block
05-11-2012 09:58 AM in reply to: ericwhitmore
ericwhitmore wrote:
.... Basically, you run the Lisp command, select whatever you want and it instantly transforms your selection into a randomly named block.  I think I got this routine off of a Hot Tip Harry website a LONG time ago.
This is from Hot Tip Harry's website [Cadalyst] -- might it be the one?  It doesn't name it randomly, though.  And I didn't download it and try it.  But it came up when I searched for "quick block":
http://cadtips.cadalyst.com/standard-blocks/quick-blocks
Kent Cooper
_Tharwat
Message 7 of 8 (351 Views)
Re: Quick block
Enjoy it . :smileywink:
Tharwat
Member
ericwhitmore
Message 8 of 8 (347 Views)
Re: Quick block
05-11-2012 10:06 AM in reply to: Kent1Cooper
Thanks, this really helps!
