• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Visual LISP, AutoLISP and General Customization
    Member
    Quick block
    170 Views, 7 Replies
    05-11-2012 09:06 AM
    I have migrated o a new office and I am looking for a Lisp routine that used to make Blocks in-place instantly.  he name of the block doesn't matter, but it can't be an anonymous block (I already have that routine!)
    Does anyone have this lisp routine they could share?  Basically, you run the Lisp command, select whatever you want and it instantly transforms your selection into a randomly named block.  I think I got this routine off of a Hot Tip Harry website a LONG time ago.
    HELP!
    Please use plain text.
    Valued Mentor
    _Tharwat
    Re: Quick block
    05-11-2012 09:32 AM in reply to: ericwhitmore
    Things like this .... ?
    (defun c:Test (/ selectionset insertionpoint number Blockname)
      ;;; Tharwat 11. May. 2012 ;;
      (if (and (setq selectionset (ssget "_:L"))
               (setq insertionpoint (getpoint "\n Specify insertion point :"))
        (progn
          (setq number    1
                Blockname (strcat "MyBlock" (itoa number))
          (while (tblsearch "BLOCK" Blockname)
            (setq Blockname
                   (strcat "MyBlock" (itoa (setq number (1+ number))))
          (command "_.-Block" Blockname insertionpoint selectionset ""
        (princ)
      (princ)
    Member
    Re: Quick block
    05-11-2012 09:37 AM in reply to: _Tharwat
    Almost!  I ran this lisp and it deletes the original content, but I just want to convert a selection to a named block, in place, without having to reinsert it.
    THANK YOU FOR YOUR HELP!
    Valued Mentor
    _Tharwat
    Re: Quick block
    05-11-2012 09:43 AM in reply to: ericwhitmore
    With the adds of command call insert , we will re-insert the same block name in its chosen insertion point . :smileyvery-happy:
    Try and tell me back ..
        (progn
          (setq number    1
            (setq Blockname
          (command "_.-Block" Blockname insertionpoint selectionset "")
          (command "_.-insert" Blockname insertionpoint "" "" "")
        (princ)
      (princ)
    Member
    Re: Quick block
    05-11-2012 09:57 AM in reply to: _Tharwat
    Perfect!!!  Way to go!
    Kent1Cooper
    Re: Quick block
    05-11-2012 09:58 AM in reply to: ericwhitmore
    ericwhitmore wrote:
    .... Basically, you run the Lisp command, select whatever you want and it instantly transforms your selection into a randomly named block.  I think I got this routine off of a Hot Tip Harry website a LONG time ago.
    This is from Hot Tip Harry's website [Cadalyst] -- might it be the one?  It doesn't name it randomly, though.  And I didn't download it and try it.  But it came up when I searched for "quick block":
    http://cadtips.cadalyst.com/standard-blocks/quick-blocks
    Kent Cooper
    Valued Mentor
    _Tharwat
    Re: Quick block
    Enjoy it . :smileywink:
    Tharwat
    Member
    Re: Quick block
    05-11-2012 10:06 AM in reply to: Kent1Cooper
    Thanks, this really helps!
