I have migrated o a new office and I am looking for a Lisp routine that used to make Blocks in-place instantly. he name of the block doesn't matter, but it can't be an anonymous block (I already have that routine!)
Does anyone have this lisp routine they could share? Basically, you run the Lisp command, select whatever you want and it instantly transforms your selection into a randomly named block. I think I got this routine off of a Hot Tip Harry website a LONG time ago.
HELP!
Solved by _Tharwat. Go to Solution.
Things like this .... ?
(defun c:Test (/ selectionset insertionpoint number Blockname) ;;; Tharwat 11. May. 2012 ;; (if (and (setq selectionset (ssget "_:L")) (setq insertionpoint (getpoint "\n Specify insertion point :")) ) (progn (setq number 1 Blockname (strcat "MyBlock" (itoa number)) ) (while (tblsearch "BLOCK" Blockname) (setq Blockname (strcat "MyBlock" (itoa (setq number (1+ number)))) ) ) (command "_.-Block" Blockname insertionpoint selectionset "" ) ) (princ) ) (princ) )
Almost! I ran this lisp and it deletes the original content, but I just want to convert a selection to a named block, in place, without having to reinsert it.
THANK YOU FOR YOUR HELP!
With the adds of command call insert , we will re-insert the same block name in its chosen insertion point .
Try and tell me back ..
(defun c:Test (/ selectionset insertionpoint number Blockname) ;;; Tharwat 11. May. 2012 ;; (if (and (setq selectionset (ssget "_:L")) (setq insertionpoint (getpoint "\n Specify insertion point :")) ) (progn (setq number 1 Blockname (strcat "MyBlock" (itoa number)) ) (while (tblsearch "BLOCK" Blockname) (setq Blockname (strcat "MyBlock" (itoa (setq number (1+ number)))) ) ) (command "_.-Block" Blockname insertionpoint selectionset "") (command "_.-insert" Blockname insertionpoint "" "" "") ) (princ) ) (princ) )
@Anonymous wrote:.... Basically, you run the Lisp command, select whatever you want and it instantly transforms your selection into a randomly named block. I think I got this routine off of a Hot Tip Harry website a LONG time ago.
This is from Hot Tip Harry's website [Cadalyst] -- might it be the one? It doesn't name it randomly, though. And I didn't download it and try it. But it came up when I searched for "quick block":
http://cadtips.cadalyst.com/standard-blocks/quick-blocks
@_Tharwat wrote:With the adds of command call insert , we will re-insert the same block name in its chosen insertion point .
Hi @_Tharwat ,
Thanks for this lisp. It's very useful for me.
What if I want to specify the block name instead of automatic, what should I add on your code?
Thank you.
Just this a shot.
(defun c:Test (/ selectionset insertionpoint Blockname)
;;; Tharwat 13. Jul. 2020 ;;
(setq insertionpoint (getpoint "\nSpecify insertion point :"))
(setq Blockname (getstring t "\nSpecify Block name :"))
(setq Blockname (vl-string-left-trim " " Blockname))
(if (or (= Blockname "")
(not (snvalid Blockname))
(alert "Invalid block name, or its already existed!")
Blockname)
(progn
(command "_.-Block" Blockname "_none" insertionpoint selectionset "")
(command "_.-insert" Blockname "_none" insertionpoint "" "" "")
(princ)
(princ)
) (vl-load-com)
