Visual LISP, AutoLISP and General Customization
Question about Handles in Autocad
1 REPLY 1
dwcreston
297 Views, 1 Reply
Good Evening,
quick question at the end of the day. I have spent a half hour reading up on handles and understand each block or attributes have to to be automatically numbered by autocad.
My question:
is using the same block with the same handles(will not work if the block has different handles) in multiple drawings just fundamentally easier to modify through excel or notepad? Is this a great way to save fonts and text sizing within a block?
seems that it would be a better tool if the command could take the attributes and applythem to blocks of different shapes and sizes.
I just wanna see the broader picture.
Thanks for the support in earlier posts!
Dan
I want to be able to make a txt file, and change all the attributes within a titleblock instead of having to open attributes after I open the drawing.
I can open the txt file with notepad and all the information is there for me to change the values.
I am using a full autocad version with express tools and tinkering around with attin and attout.
1 REPLY 1
hmsilva
in reply to: dwcreston
Try
Command: ATTOUT
and
Command:ATTIN
Henrique
”Boost
