@Anonymous wrote:
How do I find them ?
I want to retain old qleader-mtext setting then change to "none" text.
After lisp routine adds qlader to dwg then I rest qleader back to old mtext setting.
The settings are stored under the Named Object Dictionary, within either the acaddim or acaddim_crx dictionary, depending on the version of AutoCAD you are using.
And here is a reference for the various DXF group codes, courtesy of Frank Whaley of Autodesk:
;;; 3: user arrowhead block name (default="") ;;; 40: default text width (default=0.0) ;;; 60: annotation type (default=0) ;;; 0=MText ;;; 1=copy object ;;; 2=Tolerance ;;; 3=block ;;; 4=none ;;; 61: annotation reuse (default=0) ;;; 0=none ;;; 1=reuse next ;;; 62: left attachment point (default=1) ;;; 63: right attachment point (default=3) ;;; 0=Top of top line ;;; 1=Middle of top line ;;; 2=Middle of multiline text ;;; 3=Middle of bottom line ;;; 4=Bottom of bottom line ;;; 64: underline bottom line (default=0) ;;; 65: use splined leader line (default=0) ;;; 66: no limit on points (default=0) ;;; 67: maximum number of points (default=3) ;;; 68: prompt for MText width (word wrap) (default=1) ;;; 69: always left justify (default=0) ;;; 70: allowed angle, first segment (default=0) ;;; 71: allowed angle, second segment (default=0) ;;; 0=Any angle ;;; 1=Horizontal ;;; 2=90deg ;;; 3=45deg ;;; 4=30deg ;;; 5=15deg ;;; 72: frame text (default=0) ;;; 170: active tab (default=0) ;;; 0=Annotation ;;; 1=Leader Line & Arrow ;;; 2=Attachment ;;; 340: object ID for annotation reuse
Thanks Lee_Mac... Now i've found the issue...
the problem is the name of the dictionary that has changed...
if one has customized the leaders, change the dictionary name and that's all...
Thanks again
Hi Armando,
do a search at 'Search This Board' for acet-ql-get, acet-ql-set, qlset.lsp or Frank Whaley,...
and you'll find an exemple by Frank Whaley, Autodesk
Please, pay attention to what Lee Mac have stated in is post:
'The settings are stored under the Named Object Dictionary, within either the acaddim or acaddim_crx dictionary, depending on the version of AutoCAD you are using.'
Hope that helps
Henrique
hmsilva this is the file I loaded and I typed acet-ql-get into the command line and thing happens. I copy the text exactly as they have it and tried modifying the file to work for me to change (63 . 3) to (63 . 1) and I can’t finger it out. Can you please review it let me know were those the modifications need to happen? I need to make this work, and I don’t know too. It’s so frustrating, I know it has to be something really easy but I can’t see it.
I also replace (acet-ql-get ) for (acet-ql-set '((63 . 1))) did not work.
I also replace AcadDim for acaddim_crx did not work.
Im also using Autocad 14 and 15 I dont know if that matters or not.
Armando,
for AC2014/15, try the modified code.
Load the code, enter (acet-ql-set '((63 . 1))) and the default right attachment point will be modified to 'Middle of top line', means the new qleader will be created with those settings.
Hope that helps
Henrique
@armando1903 wrote:
I loaded the file "qlset_V1.lsp" you gave me with modifying it. When you said “enter (acet-ql-set '((63 . 1)))" what do mean? Do I create a new command with (acet-ql-set '((63 . 1))?
Enter in command line (acet-ql-set '((63 . 1))) was just for testing purpose...
If you need a command to set the default right attachment point to 'Middle of top line', just add this code lines after the end of the code at qlset_V1.lsp
(defun c:demo ();; change demo to suits (acet-ql-set '((63 . 1))) (princ) )
HTH
Henrique
OMG!!! THANK YOU SO MUCH THAT WORKED!!!
I apologize in the other message I meant to say “I loaded the file "qlset_V1.lsp" you gave me WITHOUT modifying it“
So I understand loading the qlset_V1.lsp file you gave me without modifying it was to change the (acet-ql-set '((63 . 1))) setting for every drawing I open?
That did not happen when I loaded it.
You're welcome, Armando!
Armando,
I just did change the Dictionary Name, in order to work with AC2014/2015.
Frank Whaley's qlset.lsp have two functions, the 'acet-ql-get' that 'Returns an association list containing the current QLEADER settings from the Named Object Dictionary', and 'acet-ql-set' that ' Sets the specified values for QLEADER settings from the given association list.'
Just loading the code, nothing happens, only defined functions are loaded into the current dwg.
To change some setting in QLEADER, we can use the 'acet-ql-set' function.
To use as a command, (as my previous post) we need to define a function (or a button) to call the 'acet-ql-set' function that requires as argument a list of dotted pairs.
If your goal is to load the file and set the default right attachment point to 'Middle of top line' in all the files that you open without user intervention, just add
Henrique
