try this... this is just the code from the lisp
file
(ql-get)
;; Returns an association list
containing the current QLEADER
;; settings from
the Named Object Dictionary.
;; (ql-get
<alist>)
;; Sets the specified values for
QLEADER settings from the given
;; association
list. Returns an association list containing
the
;; new values.
;; These
functions can be used to examine the current QLEADER
;; settings, or to
initialize the setting before using the QLEADER
;; command. For
example, to use splined leaders and framed text:
(ql-set '((65 . 1)(72 . 1)))
;; Both functions use the following
group codes to identify QLEADER
settings:
;; 3: user arrowhead block name
(default="")
;; 40: default text width
(default=0.0)
;; 60: annotation type
(default=0)
0=MText
;; 1=copy
object
2=Tolerance
3=block
4=none
;; 61: annotation reuse
(default=0)
0=none
;; 1=reuse
next
;; 62: left attachment point
(default=1)
;; 63: right attachment point
(default=3)
;; 0=Top of top
line
;; 1=Middle of top
line
;; 2=Middle of multiline
text
;; 3=Middle of bottom
line
;; 4=Bottom of bottom
line
;; 64: underline bottom line
(default=0)
;; 65: use splined leader line
(default=0)
;; 66: no limit on points
(default=0)
;; 67: maximum number of points
(default=3)
;; 68: prompt for MText width (word wrap)
(default=1)
;; 69: always left justify
(default=0)
;; 70: allowed angle, first segment
(default=0)
;; 71: allowed angle, second segment
(default=0)
;; 0=Any
angle
1=Horizontal
2=90deg
3=45deg
4=30deg
5=15deg
;; 72: frame text (default=0)
170: active tab (default=0)
0=Annotation
;; 1=Leader Line &
Arrow
2=Attachment
;; 340: object ID for annotation reuse
(DEFUN *ERROR* (MSG)
(PRINC)
(DEFUN QL-GET (/ XR COD ITM REPLY)
(IF
(SETQ XR (DICTSEARCH (NAMEDOBJDICT) "AcadDim"))
(PROGN
(FOREACH
COD
'(3 40 60 61 62 63 64 65 66 67
68 69 70 71 72 170 340)
(IF (SETQ ITM (ASSOC COD XR))
(SETQ REPLY (APPEND REPLY (LIST
ITM)))
REPLY
'((3 . "")
(40 .
0.0)
(60 .
0)
(61 . 0)
(62 . 1)
(63 .
1)
(64 . 0)
(65 . 1)
(66 .
0)
(67 . 3)
(68 . 0)
(69 .
0)
(70 . 0)
(71 . 0)
(72 .
0)
(170 . 0)
(DEFUN QL-SET (ARG / CUR PRM)
(SETQ CUR
(QL-GET))
(WHILE ARG
(SETQ PRM (CAR
ARG)
ARG (CDR ARG)
CUR (SUBST PRM (ASSOC (CAR
PRM) CUR) CUR)
(IF (= 3 (CAR
PRM))
(SETVAR "DIMLDRBLK" (CDR
PRM))
(DICTREMOVE (NAMEDOBJDICT)
"AcadDim")
(SETQ
CUR (APPEND '((0 .
"XRECORD") (100 . "AcDbXrecord") (90 .
990106))
CUR
(DICTADD
(NAMEDOBJDICT) "ACADDIM" (ENTMAKEX CUR))
(QL-GET)
(DEFUN c:qlsettings (/
ANNOTYPE TXTWIDTH
MTXTWDTH
LJUSTIFY
FRAMETXT LATTPNT
RATTPNT
UBOTTOM
ANNREUSE USESPLIN
MAXNMPNT
NOLIMPNT
ABLKNAME FANGLE SANGLE
(INITGET "Mtext Copy Tolerance Block None _0 1 2 3 4")
(SETQ ANNOTYPE
(GETKWORD
"\nAnnotation type
[Mtext/Copy object/Tolerance/Block/None] <Mtext>: "
(IF (= ANNOTYPE NIL)
(SETQ ANNOTYPE
"0")
(IF (= ANNOTYPE "0")
(PROGN
(INITGET "No Yes _0
1")
(SETQ TXTWIDTH
(GETKWORD
"\nPrompt for
MText width [Yes/No] <Yes>: "
(IF (=
TXTWIDTH NIL)
(SETQ TXTWIDTH "1")
(IF (= TXTWIDTH
"1")
(PROGN
(INITGET 4)
(SETQ MTXTWDTH
(GETREAL
(STRCAT
"\nDefault text width <"
(RTOS 0.0 (GETVAR
"LUNITS") (GETVAR "LUPREC"))
(IF (= MTXTWDTH NIL)
(SETQ MTXTWDTH
0.0)
(INITGET "No Yes _0 1")
(SETQ
LJUSTIFY (GETKWORD "\nAlways left justify [Yes/No] <No>:
(IF (=
LJUSTIFY NIL)
(SETQ LJUSTIFY "0")
(INITGET "No Yes _0
1")
(SETQ FRAMETXT (GETKWORD "\nFrame text
[Yes/No] <No>: "))
(IF (= FRAMETXT
NIL)
(SETQ FRAMETXT "0")
(INITGET "TT MT MM MB BB _0 1 2 3
4")
(SETQ
LATTPNT (GETKWORD
"\nLeft attachment
point [TT/MT/MM/MB/BB] <MT>:
(IF (= LATTPNT NIL)
(SETQ LATTPNT
"1")
(INITGET "TT MT MM MB BB _0 1 2 3 4")
(SETQ
RATTPNT (GETKWORD
"\nRight attachment
point [TT/MT/MM/MB/BB] <MM>:
(IF (= RATTPNT NIL)
(SETQ RATTPNT
"3")
(SETQ
UBOTTOM
(GETKWORD "\nUnderline bottom line
[Yes/No] <No>: ")
(IF (= UBOTTOM NIL)
(SETQ UBOTTOM
"0")
(INITGET "None Reuse _0 1")
(SETQ ANNREUSE
(GETKWORD "\nAnnotation reuse [None/Reuse next] <None>: "
(IF (= ANNREUSE NIL)
(SETQ
ANNREUSE "0")
(SETQ
USESPLIN (GETKWORD "\nUse splined leader [Yes/No] <No>: "))
(IF
(= USESPLIN NIL)
(SETQ USESPLIN "0")
(INITGET 6)
(SETQ
MAXNMPNT (GETINT "\nNumber of
points or <Enter> for no limit: ")
(IF (= MAXNMPNT
NIL)
(PROGN
(SETQ
MAXNMPNT "2")
(SETQ NOLIMPNT
"1")
(SETQ ABLKNAME
(GETKWORD
"\nUser arrowhead block name or <Enter>
for none: "
(IF (= ABLKNAME
NIL)
(SETQ ABLKNAME "")
(INITGET
"Any Horizontal 90 45 30 15 _0 1 2 3 4 5")
(SETQ FANGLE
(GETKWORD
"\nFirst segment angle constraint [Any
angle/Horizontal/90/45/30/15] <Any>: "
(IF (= FANGLE NIL)
(SETQ FANGLE "0")
(INITGET "Any Horizontal 90 45 30 15 _0 1 2 3 4 5")
(SETQ SANGLE
(GETKWORD
"\nSecond segment
angle constraint [Any angle/Horizontal/90/45/30/15] <Any>: "
(IF (= SANGLE NIL)
(SETQ SANGLE
"0")
(QL-SET
(LIST (CONS 3
ABLKNAME)
(CONS 40 MTXTWDTH)
(CONS 60 (ATOI
ANNOTYPE))
(CONS 61 (ATOI ANNREUSE))
(CONS 62
(ATOI LATTPNT))
(CONS 63 (ATOI RATTPNT))
(CONS
64 (ATOI UBOTTOM))
(CONS 65 (ATOI USESPLIN))
(CONS 66 (ATOI NOLIMPNT))
(CONS 67 (ATOI
MAXNMPNT))
(CONS 68 (ATOI TXTWIDTH))
(CONS 69
(ATOI LJUSTIFY))
(CONS 70 (ATOI FANGLE))
(CONS
71 (ATOI SANGLE))
(CONS 72 (ATOI FRAMETXT))
(CONS 170 0)
(PRINC)
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
This
lisp sounds just like what I am looking for. When I click on the lisp it gives
me a message "No Attachments"
am I doing something wrong? Would really
like to get my hands on this code.
Thanks!
