Visual LISP, AutoLISP and General Customization
Put block elements back in original position
3 REPLIES 3
erickson123
360 Views, 3 Replies
I have lots of the same block with attributes. Someone has moved the elements (the attributes) all around using grips and now it is a big mess. Is there any command to make the block attributes revert back to the original position? This drawing comes from a consulant so I can't get anything elce.
3 REPLIES 3
in reply to: erickson123
look at
http://discussion.autodesk.com/forums/thread.jspa?threadID=721149&tstart=15
frankrains
Try using either ATTSYNC or BATTMAN.
erickson123
I ended up using attredef which worked-
”Boost
