Visual LISP, AutoLISP and General Customization
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Put Default Text on Command Line for getstring
- Highlight
- Email to a Friend
Hi All,
I am trying to get a default value (from global variable) put as the default for getstring command. Problem is I want it as if I had typed it into the getstring command so I can modify it if required. It is for entering filenames which only change slightly ie 1129E09LS1 ...LS2 ...XS1 etc.
Any ideas???
Current Code:
(setq BlkName (getstring "\nEnter Civil Cad File to Import: "))
For defaults that I don't want to change I usually use this format:
(or BlkName (setq BlkName (getstring "\nEnter Civil Cad File to Import: ")))
Thanks In Advance
Steve :-)
Re: Put Default Text on Command Line for getstring
- Highlight
- Email to a Friend
Maybe ..... change the [My File Name] to your needed one .
(if (eq (setq BlkName (getstring "\nEnter Civil Cad File to Import [My File Name] : ")) "") (setq BlkName "My File Name"))
- Highlight
- Email to a Friend
Play around with this one
(defun c:Test ()
(setq BlkName (lisped (if (or (null BlkName)
(numberp BlkName))
"" (strcase BlkName))))
- Highlight
- Email to a Friend
(defun c:Test ()
(numberp BlkName))
Hi pBe .
What's this lisped ?? You must have forgotten to add that sub-function ![]()
- Highlight
- Email to a Friend
_Tharwat wrote:Hi pBe .
Did you try it?
- Highlight
- Email to a Friend
Did you try it?
That's awesome . ![]()
- Highlight
- Email to a Friend
pbejse wrote:....
(numberp BlkName))
That is awesome, as _Tharwat said. It is beyond my comprehension why a function like (lisped) would not be included in the AutoLISP Reference [it can't be that it's newer than my old version, because the function is present]. How is anyone supposed to know about it?
- Highlight
- Email to a Friend
Thanks heaps pbejse!!!!
I ended up copying lisped out of acad.dcl and modifying it to suit my needs and using your code.
;Call DCL to display dialog with previous BlkName if it Exists
(setq BlkName (CCIdcl
(if (or (null BlkName) (numberp BlkName));or
);if
);CCIdcl
);setq
;Check if BlkName /= ""
(cond
((= "" BlkName)
(princ "\n No Filename Entered - Function Cancelled")
);Cond BlkName = ""
( T
(progn
... Code to run here ...
);progn
);cond BlkName Exists
);cond lisped changed to CCIdcl, modified labels & removed mtext editor button
(defun CCIdcl (contents / fname dcl state)
;;;(if (not (setq fname (getvar "program")))
(setq fname "BK-Std")
(strcat fname ".dcl")
(setq dcl (load_dialog fname))
(if (not (new_dialog "CCI" dcl)) (exit))
(set_tile "contents" contents)
(mode_tile "contents" 2)
(action_tile "contents" "(setq contents $value)")
(action_tile "accept" "(done_dialog 1)")
;;; (action_tile "mtexted" "(done_dialog 2)" )
(setq state (start_dialog))
(unload_dialog dcl)
(cond
((= state 1) contents)
((= state 2) -1)
(t 0)
);cond
);defunThanks again for your help!
Steve :-)
- Highlight
- Email to a Friend
Prac_Slip_Kerm wrote:Thanks heaps pbejse!!!!
You are welocme, glad i could help
Keep on coding,
Cheers
- Highlight
- Email to a Friend
Cool huh? ![]()
One soruce is thru atoms-list function, when evaluating an item you will get #<USUBR @161e3e24 LISPED> , and its unrecognizable then you'll start to wonder what that is...the local search button on this forum or Mr. google will find it for you.
Most of the time i just jumped from one forum to another. ![]()
Another source is JTB World Undocumented section or Manusoft
HTH
