Hi All,
I am trying to get a default value (from global variable) put as the default for getstring command. Problem is I want it as if I had typed it into the getstring command so I can modify it if required. It is for entering filenames which only change slightly ie 1129E09LS1 ...LS2 ...XS1 etc.
Any ideas???
Current Code:
(setq BlkName (getstring "\nEnter Civil Cad File to Import: "))
For defaults that I don't want to change I usually use this format:
(or BlkName (setq BlkName (getstring "\nEnter Civil Cad File to Import: ")))
Thanks In Advance
Solved by _Tharwat. Go to Solution.
Solved by pbejse. Go to Solution.
Maybe ..... change the [My File Name] to your needed one .
(if (eq (setq BlkName (getstring "\nEnter Civil Cad File to Import [My File Name] : ")) "") (setq BlkName "My File Name"))
Play around with this one
(defun c:Test ()
(setq BlkName (lisped (if (or (null BlkName)
(numberp BlkName))
"" (strcase BlkName))))
(defun c:Test ()
(numberp BlkName))
Hi pBe .
What's this lisped ?? You must have forgotten to add that sub-function
@pbejse wrote:....
(numberp BlkName))
That is awesome, as _Tharwat said. It is beyond my comprehension why a function like (lisped) would not be included in the AutoLISP Reference [it can't be that it's newer than my old version, because the function is present]. How is anyone supposed to know about it?
Thanks heaps pbejse!!!!
I ended up copying lisped out of acad.dcl and modifying it to suit my needs and using your code.
;Call DCL to display dialog with previous BlkName if it Exists (setq BlkName (CCIdcl (if (or (null BlkName) (numberp BlkName));or "" (strcase BlkName) );if );CCIdcl );setq ;Check if BlkName /= "" (cond ((= "" BlkName) (princ "\n No Filename Entered - Function Cancelled") );Cond BlkName = "" ( T (progn ... Code to run here ... );progn );cond BlkName Exists );cond
lisped changed to CCIdcl, modified labels & removed mtext editor button
(defun CCIdcl (contents / fname dcl state) ;;;(if (not (setq fname (getvar "program"))) (setq fname "BK-Std") ;;;) (strcat fname ".dcl") (setq dcl (load_dialog fname)) (if (not (new_dialog "CCI" dcl)) (exit)) (set_tile "contents" contents) (mode_tile "contents" 2) (action_tile "contents" "(setq contents $value)") (action_tile "accept" "(done_dialog 1)") ;;; (action_tile "mtexted" "(done_dialog 2)" ) (setq state (start_dialog)) (unload_dialog dcl) (cond ((= state 1) contents) ((= state 2) -1) (t 0) );cond );defun
Thanks again for your help!
@Prac_Slip_Kerm wrote:Thanks heaps pbejse!!!!
You are welocme, glad i could help
Keep on coding,
Cheers
Cool huh?
One soruce is thru atoms-list function, when evaluating an item you will get #<USUBR @161e3e24 LISPED> , and its unrecognizable then you'll start to wonder what that is...the local search button on this forum or Mr. google will find it for you.
Most of the time i just jumped from one forum to another.
Another source is JTB World Undocumented section or Manusoft
HTH
