• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Visual LISP, AutoLISP and General Customization
    Prac_Slip_Kerm
    Accepted Solution
    Put Default Text on Command Line for getstring
    334 Views, 9 Replies
    06-06-2012 10:31 PM
    Hi All,
      I am trying to get a default value (from global variable) put as the default for getstring command. Problem is I want it as if I had typed it into the getstring command so I can modify it if required. It is for entering filenames which only change slightly ie 1129E09LS1 ...LS2 ...XS1 etc.
    Any ideas???
    Current Code:
    (setq BlkName (getstring "\nEnter Civil Cad File to Import: "))
    For defaults that I don't want to change I usually use this format:
    (or BlkName (setq BlkName (getstring "\nEnter Civil Cad File to Import: ")))
     Thanks In Advance
    Cheers
    Steve :-)
    Please use plain text.
    Valued Mentor
    _Tharwat
    Re: Put Default Text on Command Line for getstring
    06-06-2012 11:13 PM in reply to: Prac_Slip_Kerm
    Maybe ..... change the [My File Name] to your needed one .
    (if (eq (setq BlkName (getstring  "\nEnter Civil Cad File to Import [My File Name] : ")) "")
      (setq BlkName "My File Name"))
    *Expert Elite*
    06-07-2012 01:09 AM in reply to: _Tharwat
    Play around with this one
    (defun c:Test ()
     (setq BlkName (lisped (if (or (null BlkName)
                                          (numberp BlkName))
                                         "" (strcase BlkName))))
    Valued Mentor
    _Tharwat
    06-07-2012 01:23 AM in reply to: pbejse
    (defun c:Test ()
                                          (numberp BlkName))
    Hi pBe .
    What's this lisped ?? You must have forgotten to add that sub-function  :smileywink:
    *Expert Elite*
    06-07-2012 01:37 AM in reply to: _Tharwat
    _Tharwat wrote:
    Hi pBe .
    Did you try it?
    Valued Mentor
    _Tharwat
    06-07-2012 01:42 AM in reply to: pbejse
    pbejse wrote:
    _Tharwat wrote:
    Hi pBe .
    Did you try it?
    That's awesome . :smileyvery-happy:
    *Expert Elite*
    Kent1Cooper
    06-07-2012 11:53 AM in reply to: pbejse
                                          (numberp BlkName))
    That is awesome, as _Tharwat said.  It is beyond my comprehension why a function like (lisped) would not be included in the AutoLISP Reference [it can't be that it's newer than my old version, because the function is present].  How is anyone supposed to know about it?
    Kent Cooper
    Prac_Slip_Kerm
    06-07-2012 06:02 PM in reply to: pbejse
    Thanks heaps pbejse!!!!
    I ended up copying lisped out of acad.dcl and modifying it to suit my needs and using your code.
    ;Call DCL to display dialog with previous BlkName if it Exists
      (setq BlkName (CCIdcl
    		  (if (or (null BlkName) (numberp BlkName));or
    		  );if
    		 );CCIdcl
      );setq
      ;Check if BlkName /= ""
      (cond
        ((= "" BlkName)
          (princ "\n No Filename Entered - Function Cancelled")
        );Cond BlkName = ""
        ( T
          (progn
            ... Code to run here ...
          );progn
        );cond BlkName Exists
      );cond
     lisped changed to CCIdcl, modified labels & removed mtext editor button
    (defun CCIdcl (contents / fname dcl state)
      ;;;(if (not (setq fname (getvar "program")))
      (setq fname "BK-Std")
      (strcat fname ".dcl")
      (setq dcl (load_dialog fname))
      (if (not (new_dialog "CCI" dcl)) (exit))
      (set_tile "contents" contents)
      (mode_tile "contents" 2)
      (action_tile "contents" "(setq contents $value)")
      (action_tile "accept" "(done_dialog 1)")
    ;;;  (action_tile "mtexted" "(done_dialog 2)" )
      (setq state (start_dialog))
      (unload_dialog dcl)
      (cond
        ((= state 1) contents)
        ((= state 2) -1)
        (t 0)
      );cond
    );defun
     Thanks again for your help!
    Cheers
    Steve :-)
    *Expert Elite*
    06-07-2012 09:54 PM in reply to: Prac_Slip_Kerm
    You are welocme, glad i could help
    Keep on coding,
    Cheers
    *Expert Elite*
    06-08-2012 04:35 AM in reply to: Kent1Cooper
    Cool huh? :smileyhappy:
    One soruce is thru atoms-list function, when evaluating  an item you will get #<USUBR @161e3e24 LISPED> , and its unrecognizable  then you'll start to wonder what that is...the local search button on this forum or Mr. google will find it for you.
    Most of the time i just jumped from one forum to another. :smileyvery-happy:
    Another source is  JTB World Undocumented section  or Manusoft
    HTH
