Visual LISP, AutoLISP and General Customization
Valued Contributor
masa10789
Message 1 of 3 (652 Views)
Publish through vlisp
652 Views, 2 Replies
02-01-2007 10:34 AM
Can you programmatically access the publish function? I couln't find it. Is it not similar to (vla-PlotTofile (vla-get-activedocument (vla-get-acad-object)) "c:\\myfilename.dwf")?
Any help would be great, thanks.
*CADDee.com
Message 2 of 3 (652 Views)
Re: Publish through vlisp
02-01-2007 01:34 PM in reply to: masa10789
What I have done is use VBA to write a DDS file and then...
(command "-publish" (strcat (getvar "dwgprefix") "\PublishJob.DSD"))
The DDS file, as you may know, is the file format for a publish "job", it's
very much like an INI file. This file could also be written by lisp but
probably easier with VB or VBA.
Jim Dee
www.caddee.com
wrote in message news:5471890@discussion.autodesk.com...
Valued Contributor
masa10789
Message 3 of 3 (652 Views)
02-02-2007 07:28 AM in reply to: masa10789
Thanks for the help. Seems easy enough to do.
You are not logged in.
Announcements
Need installation help?
Ask the Community
