Problem with pickcsv autolisp
3 REPLIES 3
sireath
348 Views, 3 Replies
I have a problem with my autolisp. It was working fine until recently. The purpose of the autolisp is to select the point and it will automatically generate a csv file. However recently it is unable to generate the csv file. Can anyone help solve that part?
below is the codes.
(defun c:pickcsv()
(setq name (getstring "\nkey in file name:"))
(setq rad (getreal "\nkey in radius for circle (0 for no circle):"))
(setq th (getreal "\nkey in text height:"))
(setq rta (getstring "\nkey in rotation angle:"))
(setq mark (getstring "\nkey in mark layer: [mark]"))
(if (= mark "") (setq mark "mark"))
(setq num (getstring "\nkey in num layer: [num]"))
(if (= num "") (setq num "num"))
(setq f (open name "a"))
;;;(write-line "00NMSDR20 V02-03S123401-MAY-00 00:00 111111" f)
(setq i 1)
(initget "New")
(setq cor (getpoint "\nNew point number / <pick point>: "))
(while (/= cor nil)
(if (= cor "New")
(setq i (getint "\nkey in number:"))
(progn
(command "layer" "make" mark "")
(if (/= rad 0.0) (command "circle" cor rad))
(command "layer" "make" num "")
(setq ii (itoa i))
(setq cor1 (polar cor th th))
(command "_.text" cor1 th rta ii)
(setq x (rtos (car cor)))
(setq y (rtos (cadr cor)))
(setq z (rtos (caddr cor)))
;;;(setq li (strlen ii))
;;;(setq lx (strlen x) )
;;;(setq ly (strlen y) )
;;;(setq lli (- 4 li))
;;;(setq llx (- 10 lx))
;;;(setq lly (- 10 ly))
;;;(repeat lli (setq ii (strcat "0" ii)))
;;;(repeat llx (setq x (strcat x " ")))
;;;(repeat lly (setq y (strcat y " ")))
;;;(setq s (strcat "08KI" ii y x))
(setq s (strcat ii "," y "," x "," z ",PT"))
(setq s1 (strcat"current point " ii " N: " y " E: " x))
(write-line s1)
(write-line s f)
(setq i (+ i 1))
(initget "New")
(close f)
3 REPLIES 3
Ajilal.Vijayan
in reply to: sireath
Try by changing this line
 to something like this.
Then it will ask you to select a location for the file.
(setq name (getfiled "Select File" "" "csv" 1))
sireath
Thanks! Solved my problems and headache.
Ajilal.Vijayan
Welcome to Autodesk Forum !!
I am glad I was able to help.
”Boost
