Greetings and salutations!
I posted a while back asking for help regarding a program which would automatically insert blocks at certain points. I'm both proud and ashamed to say that I've completed said program. Proud, because it functions smoothly and I've added a good deal of meat to it. Ashamed, because I'm still not entirely sure why it works. But, that's why we have Google I suppose.
Getting to the point, this program shows me something with crystal clarity that I had known since the beginning but never gave much thought, as I didn't care much of the extraneous results so long as the program completed its task. I speak of the command line text. Example, when you insert a block using your LISP program, the command line prints the text that you would see if you had inserted the block from the command line:
Command: _insert Enter block name or [?] : C:/Documents and Settings/Administrator/Desktop/SYMBOLS/WG.dwg Specify insertion point or
[Scale/X/Y/Z/Rotate/PScale/PX/PY/PZ/PRotate]:
Enter X scale factor, specify opposite corner, or [Corner/XYZ] <1>: 1 Enter Y
scale factor
