Valued Contributor
stevesfr
Message 11 of 18 (363 Views)
Re: Polyline Vertex Counter
07-30-2011 04:20 PM in reply to: azrdgldr
Ah ha, mleaderstyle...  thanks
Steve
Distinguished Contributor
GegH1
Message 12 of 18 (362 Views)
07-30-2011 04:37 PM in reply to: _Tharwat
Great tool, works perfectly.
As it happens i'm using AutoCAD 2011 64bit, it's probably the 64bit that stopped the original solution. I've been trying to learn VBSCRIPT, it took me a week to just get it to debug on a 64bit machine, nobody said the language had changed.
Thankyou so much for your time.
Creative Intentions
Win 7 Pro 64bit, Dell Precision M6500
Lee_Mac
Message 13 of 18 (359 Views)
07-30-2011 04:51 PM in reply to: GegH1
GegH1,
You received the error because the Visual LISP extensions hadn't been loaded with (vl-load-com).
Most users include this in their ACADDOC.lsp so that the Visual LISP functions are always available for programs that use them. This function only need be called once per drawing session to ensure the Visual LISP extensions are available throughout the session, which makes more sense than calling the function for each loaded program.
Another way to approach it:
(defun c:test ( / e s p )
    (if (setq s (ssget '((0 . "*POLYLINE"))))
        (while (setq e (ssname s 0))
            (vl-cmdf "_.mleader" "_non"
                (setq p (trans (vlax-curve-getendpoint e) 0 1)) "_non"
                (polar p (/ pi 4.) (* 4 (getvar 'DIMTXT)))
                (itoa (1+ (fix (vlax-curve-getendparam e))))
            (ssdel e s)
    (princ)
(vl-load-com)
Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
Expert Elite
With Mathematics there is the possibility of perfect rigour, so why settle for less?
GegH1
Message 14 of 18 (351 Views)
07-30-2011 06:23 PM in reply to: stevesfr
Lee,
Thanks for that, The code seems a lot shorter.
It constantly amaizes me how many ways there are to skin a Cat in AutoCAD.
Creative Intentions
Distinguished Mentor
_Tharwat
Message 15 of 18 (342 Views)
07-31-2011 12:48 AM in reply to: Lee_Mac
Lee .
Your routine would consider the rectanle LWpolyline ( square shapes ) as five points . :smileywink:
Tharwat
____________________________________________________
Get learn and learn and practice , to become experienced guy .
Lee_Mac
Message 16 of 18 (331 Views)
07-31-2011 04:36 AM in reply to: _Tharwat
@ GegH1,
You're very welcome :smileyhappy:
There are indeed many ways to approach the same problem with AutoCAD, especially since the drawing database can be accessed using both Vanilla AutoLISP and Visual LISP, providing effectively two interfaces for most entities. Of course, some things are easier manipulated using Vanilla (such as dictionaries), whilst others are only possible through VL.
@ Tharwat,
Good spot :smileywink:  This is because my code uses the value End Parameter (since the vertices of a Polyline have integer parameter values), however, my code didn't consider a closed polyline wherein the endpoint and startpoint are coincident.
This should fix that problem:
                (itoa (+ (fix (vlax-curve-getendparam e)) (if (vlax-curve-isclosed e) 0 1)))
            (ssdel e s)
    (princ)
(vl-load-com)
Also, you might want to consider UCS for your code :smileywink:
Expert Elite
_Tharwat
Message 17 of 18 (328 Views)
07-31-2011 04:47 AM in reply to: Lee_Mac
Yeah ... that's right .
(**** for tat) :smileyvery-happy:
Lee_Mac
Message 18 of 18 (323 Views)
07-31-2011 05:03 AM in reply to: _Tharwat
:smileywink:
Expert Elite
You are not logged in.
Ask the Community
