Visual LISP, AutoLISP and General Customization
Valued Contributor
george.drayton
Message 1 of 16 (387 Views)
Plotter name by program control
387 Views, 15 Replies
09-03-2013 04:31 PM
Has anyone a technique that can check the current plotter name for the current tab and assign it to a variable?  i.e. can it be assigned to a variable to check if if equals "myplotter1".  The next step  - is there a technique to change the plotter name to "myplotter2.pc3".
I have partially done the latter part of this in the past using the -plot command line to ASSIGN a  new plotter but I would really like to only run the routine if it really needs to.  Thanks for any help.
*Expert Elite*
hmsilva
Message 2 of 16 (362 Views)
Re: Plotter name by program control
09-04-2013 01:20 AM in reply to: george.drayton
Try
(setq AObj (vlax-get-Acad-Object)
      ADoc (vla-get-ActiveDocument AObj)
      ALyt (vla-get-ActiveLayout ADoc)
      Plt  (vla-get-Configname ALyt)
);; setq
(if (= "myplotter1" Plt)
  (vla-Put-Configname ALyt "myplotter2.pc3")
  );; if
HTH
Henrique
Valued Contributor
george.drayton
Message 3 of 16 (338 Views)
09-05-2013 02:39 PM in reply to: george.drayton
Thanks for your help once again :smileyhappy:.   The section of code (vlax-get-Configname ALyt) does not work - it produces and error.  I have loaded (vl-load-com).
I cannot find the documentation for vla-get functions (or any vla stuff in fact) in the help system - can you point me int he right direction please. Thanks
*Expert Elite*
hmsilva
Message 4 of 16 (333 Views)
09-05-2013 03:02 PM in reply to: george.drayton
You're welcome, George.
(vlax-get-Configname ALyt) is (vla-get-Configname ALyt) and should work...
For the ActiveX Help, try at the VLIDE help, at the ActiveX & VBA Reference... online
HTH
Henrique
*Expert Elite*
hmsilva
Message 5 of 16 (325 Views)
09-05-2013 03:56 PM in reply to: george.drayton
George,
maybe this way it will be easier to understand,
(defun c:test (/ ACADDOCUMENT ACADOBJECT ACTIVELAYT ACTIVEPLT)
  (vl-load-com)
  (setq AcadObject (vlax-get-acad-object))
  (setq AcadDocument (vlax-get-property AcadObject 'ActiveDocument))
  (setq ActiveLayt (vlax-get-property AcadDocument 'ActiveLayout))
  (setq ActivePlt (vlax-get-property ActiveLayt 'Configname))
  (if (= "myplotter1" ActivePlt)
    (vlax-put-property ActiveLayt 'Configname "myplotter2.pc3")
  );; if
  (princ)
 Henrique
Valued Contributor
george.drayton
Message 6 of 16 (300 Views)
09-09-2013 10:10 PM in reply to: george.drayton
Hi again,
I"m back on my project  - but it still doesn't work for me - the error show below
Command: TEST
; error: ActiveX Server returned an error: Error loading type library/DLL
*Expert Elite*
hmsilva
Message 7 of 16 (291 Views)
09-10-2013 01:02 AM in reply to: george.drayton
Hi George,
try to copy/paste
(vl-load-com)
to your command line, what is the message that you receive?
AutoCAD version?
Henrique
Valued Contributor
george.drayton
Message 8 of 16 (285 Views)
09-10-2013 01:13 AM in reply to: hmsilva
I ran your Test routine which included (vl-load-com) and got the error message   Thanks H
Valued Contributor
george.drayton
Message 9 of 16 (282 Views)
09-10-2013 01:14 AM in reply to: george.drayton
oops A2014
*Expert Elite*
hmsilva
Message 10 of 16 (281 Views)
09-10-2013 01:15 AM in reply to: george.drayton
MAC version?
You are not logged in.
Announcements
Need installation help?
Ask the Community
