Visual LISP, AutoLISP and General Customization
Plotter name by program control
15 REPLIES 15
Message 1 of 16
george.drayton
676 Views, 15 Replies
Has anyone a technique that can check the current plotter name for the current tab and assign it to a variable?  i.e. can it be assigned to a variable to check if if equals "myplotter1".  The next step  - is there a technique to change the plotter name to "myplotter2.pc3".
I have partially done the latter part of this in the past using the -plot command line to ASSIGN a  new plotter but I would really like to only run the routine if it really needs to.  Thanks for any help.
Tags (1)
15 REPLIES 15
Message 2 of 16
hmsilva
in reply to: george.drayton
Try
(setq AObj (vlax-get-Acad-Object)
      ADoc (vla-get-ActiveDocument AObj)
      ALyt (vla-get-ActiveLayout ADoc)
      Plt  (vla-get-Configname ALyt)
);; setq
(if (= "myplotter1" Plt)
  (vla-Put-Configname ALyt "myplotter2.pc3")
  );; if
HTH
Henrique
Message 3 of 16
Thanks for your help once again :).   The section of code (vlax-get-Configname ALyt) does not work - it produces and error.  I have loaded (vl-load-com).
I cannot find the documentation for vla-get functions (or any vla stuff in fact) in the help system - can you point me int he right direction please. Thanks
Message 4 of 16
hmsilva
You're welcome, George.
(vlax-get-Configname ALyt) is (vla-get-Configname ALyt) and should work...
For the ActiveX Help, try at the VLIDE help, at the ActiveX & VBA Reference... online
HTH
Henrique
Message 5 of 16
hmsilva
George,
maybe this way it will be easier to understand,
(defun c:test (/ ACADDOCUMENT ACADOBJECT ACTIVELAYT ACTIVEPLT)
  (vl-load-com)
  (setq AcadObject (vlax-get-acad-object))
  (setq AcadDocument (vlax-get-property AcadObject 'ActiveDocument))
  (setq ActiveLayt (vlax-get-property AcadDocument 'ActiveLayout))
  (setq ActivePlt (vlax-get-property ActiveLayt 'Configname))
  (if (= "myplotter1" ActivePlt)
    (vlax-put-property ActiveLayt 'Configname "myplotter2.pc3")
  );; if
  (princ)
 Henrique
Message 6 of 16
Hi again,
I"m back on my project  - but it still doesn't work for me - the error show below
Command: TEST
; error: ActiveX Server returned an error: Error loading type library/DLL
Message 7 of 16
hmsilva
Hi George,
try to copy/paste
(vl-load-com)
to your command line, what is the message that you receive?
AutoCAD version?
Henrique
Message 8 of 16
george.drayton
in reply to: hmsilva
I ran your Test routine which included (vl-load-com) and got the error message   Thanks H
Message 9 of 16
oops A2014
Message 10 of 16
hmsilva
MAC version?
Message 11 of 16
george.drayton
windows 7 32 bit
Message 12 of 16
hmsilva
George,
when I asked for copy/paste (vl-load-com), It was just to make sure that the error occurred when trying to load the ActiveX support functions.
I never had that error. but making a "Google", several people solved that issue with a repair, or a reinstall...
Maybe someone else has a better solution, let's wait and see...
Henrique
Message 13 of 16
george.drayton
windows V7
Message 14 of 16
hmsilva
@Anonymous wrote:
windows V7
Did you solve it?
Message 15 of 16
george.drayton
hi H,
I reinstalled and now when I run the line   (setq ActivePlt (vlax-get-property ActiveLayt 'Configname)) it returns the existing plotter name and no error messages.  thanks for the idea!!  rgds
George
Message 16 of 16
hmsilva
Glad you got a solution.
Henrique
”Boost
