Lou,
Thanks for the tip.
I actually responded to your post a couple of days ago, but, due to a news reader
configuration problem, my reply got sent to the wrong new server (one of the pitfalls of
using several news services I suppose).
I tried your solution, and it works great with one caveat. For some reason, the read-only
attribute of my inches.pss file keeps turning itself on. I got around this by using the
dos_attrib function from DosLib. By the way, I also use RTEXT for my plot stamps.
Chuck
"LouCancilla" wrote in message
news:f07f58e.0@WebX.maYIadrTaRb...
> Chuck,
> You can tell AutoCAD through the "-PLOTSTAMP" command.
> I use a common network ACADDOC.lsp file for a single point of administration and setup a
constant drawing environment. I load the attached code setting the plot stamp parameters.
I log the plots to a network hidden share and folder based on the windows logon name.
However I do not use the AutoCAD plot stamp anymore. I have setup RTEXT on our default
borders instead. See if this helps.
> Lou Cancilla
