Visual LISP, AutoLISP and General Customization
Please help with nested COND functions
3 REPLIES 3
2385 Views, 3 Replies
Hi All,
Please help me with the following nested "cond" function in AutoLisp.
I would like to be able to set various variables based on conditions within
conditions.
Please review the following lines and tell me what I am doing wrong.
(defun ITEMWIDTH2()
(cond
((= xitmq 2)
(and (setq itmha itm2ah itmhb itm2bh itmhc itm2ch)
(setq itmde itm1ew)(setq itmwe itm2ew)
(cond((= drbhs2 1)(setq drhs 1))((= drbhs2
2)(setq drhs 2)))
(cond((= drwhs2 1)(setq drhs 1))((= drwhs2
2)(setq drhs 2)))
);and
);cond
((= xitmq 3)
(and (setq itmha itm3ah itmhb itm3bh itmhc itm3ch)
(setq itmde (+ itm1ew itm2ew))(setq itmwe itm3ew)
(cond((= drbhs3 1)(setq drhs 1))((= drbhs3
2)(setq drhs 2)))
(cond((= drwhs3 1)(setq drhs 1))((= drwhs3
2)(setq drhs 2)))
);and
);cond
);defun
Thank you in advance,
Al
3 REPLIES 3
Hi All,
Please review the following and tell me why it is not working:
I am trying to create a conditional function within a conditional function.
(defun ITEMWIDTH2()
(cond
((= xitmq 2)
2)(setq drhs 2)))
2)(setq drhs 2)))
);and
((= xitmq 3)
2)(setq drhs 2)))
2)(setq drhs 2)))
);and
);cond
);defun
Thank you,
Al
charmingladyfool
COND is an unusual function which may take any arbitrary number of arguments. Each argument is called a clause, and consists of a list of exactly two S-expressions. We will call the first S-expression in a clause a condition, and the second S-expression a result. Thus, a call to COND looks like this:
(COND
(condition1 result1 )
(condition2 result2 )
(T    resultN ) )
The value returned by COND is computed as follows: if condition1 is true (not NIL), then return result1; else if condition2 is true then return result2; else if ...; else return resultN. In most LISP systems, it is an error if none of the conditions are true, and the result of the COND is undefined. For this reason, T is usually used as the final condition.
___________________________________________________________________________________________________________________
Copyright © 1995, 2000 by David Matuszek
All rights reserved.
Last updated October 27, 2000
I do wonder whether johnal is still waiting for a reply after more than 12 years, but anyway....
I don't think there's anything about their code that shouldn't work, and the first question I would have asked [but that was before I became a user of these Forums] would have been, "What about it doesn't work?  Does it do nothing?  Something, but not what you expect?  Is there any error message?"  Maybe some variable or other doesn't have a value set in it, or is spelled wrong, or something.  It is constructed a little oddly, though, in connection with which I would dispute what charmingladyfool posted from David Matuszek.  There can be more than one result expression evaluated/performed when a given condition returns a non-nil result, that is, the "exactly two" is incorrect:
(condition1 result1a result1b result1c ...)
(condition2 result2a result2b result2c ...)
The mis-belief that there must be only one result for each condition may be a confusion of the way (cond) works with the way (if) works.  In (if), the 'then' expression and the 'else' expression must each be a single item, and if more than one thing needs to be done, they must be wrapped into a single item using something such as (progn), though I guess (and) could be used to accomplish the same.  I suspect that's the reason for the (and) functions in johnal's code, but they are not needed.
Kent Cooper, AIA
”Boost
