Visual LISP, AutoLISP and General Customization
Passing a point list inside an active command.
7 REPLIES 7
Message 1 of 8
gccdaemon
452 Views, 7 Replies
I've been trying to to get a list of points (POINTLIST) to place each point (PT) in an active command, and the following string seems to be acting odd.
(command "-refedit" "O" "N" "CP" (foreach PT POINTLIST (Command PT)) "" "N")
This is causing a random point way out of the selection area to be generated between the first point and last point in the POINTLIST, and I'm not sure how to get around it. Any suggestions?
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
7 REPLIES 7
Message 2 of 8
hmsilva
in reply to: gccdaemon
Not much diferente, but try it
(command "-refedit" "O" "N" "CP")
(foreach pt POINTLIST (command pt))
(command "" "" "N")
HTH
Henrique
Message 3 of 8
gccdaemon
That seems to do the trick.
Next question: Is there a way to freeze/turn off objects not in the refedit selection?
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
Message 4 of 8
hmsilva
I don't see how.
A way to prevent multiple copy of the same entity, is after copy adding the entity name to a list and for the next copy test if the entity name is in the list, if so don't copy, if not, copy and add the name to de list...
HTH
Henrique
Message 5 of 8
gccdaemon
I think I'll pass the SS through the isolate command. That should take care of what I need.
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
Message 6 of 8
Lee_Mac
in reply to: hmsilva
(command "" "" "N")
HTH
Henrique
You could also use the apply function:
(command "_.-refedit" "_o" "_n" "_cp")
(apply 'command pointlist)
(command "" "" "_n")
Message 7 of 8
hmsilva
in reply to: Lee_Mac
Agree! Smiley Wink
Henrique
Message 8 of 8
Gary_J_Orr
Check out my cross post for a workaround on the "Lock Objects..." not being initialized during the "-Refeidt" command and "copy objects" selecting what should be locked problem.
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/This-is-going-to-feel-like-a-repost-b...
Gary J. Orr
(Your Friendly Neighborhood) CADD/BIM/VDC Applications Manager
http://www.linkedin.com/in/garyorr
aka (current and past user names):
Gary_J_Orr (GOMO Stuff 2008-Present); OrrG (Forum Studio 2005-2008); Gary J. Orr (LHB Inc 2002-2005); Orr, Gary J. (Gossen Livingston 1997-2002)
”Boost
