Hello everyone,
I'm using the attached lisp to change the parameters of adynamic block.
In particular, I use the function chgdynprop
(defun c: test () (setq oggfreccia (car (entsel))) (chgdynprop (Vlax-ename-> vla-object oggfreccia) "Distanze1"300.0) )
The lisp function works properly, because if I select the block from the bar I can see that property Distanze1 = 300.0
Unfortunately, however, the graphics of the block is not updated.
Do you have any advice?
Thanks in advance
