• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Visual LISP, AutoLISP and General Customization
    Member
    PLine lisp command just dont wark
    101 Views, 5 Replies
    02-06-2013 02:36 PM
    I'm asking for your help in a very simple but extremely fustrating issue.
    I'm using List pline command to draw rectangulars.
    Some of them are drawn correctly, but on some the vextex ends uo united. for example with the following command:
    (command "PLINE" (list 9.65 10.35) (list 0.65 1.35) (list 1.35 0.65) (list 10.35 9.65) "close" )
    I get a strait line instade of a rectangular.
    Please help me.
    P.S. I use Autocad 2012 for MAc.
    Please use plain text.
    Re: PLine lisp command just dont wark
    02-06-2013 02:49 PM in reply to: ersegev
    ersegev,
    perhaps something like
    (command ".pline")
    (foreach Pt '((9.65 10.35) (0.65 1.35) (1.35 0.65) (10.35 9.65)) (command Pt))
    (command "c")
     EDITED
    set "OSMODE" to zero and see if it makes difference
    hope that helps
    Henrique
    Member
    02-06-2013 03:33 PM in reply to: hmsilva
    Dear Henrique
    Eventually it was indeed the OSMODE.
    I have no idea whay even when specifically entering vertex coordinates it insists on snaping them to other coordinates.
    Any way once I turned OSMODE to 0 it worked great.
    Many thanks for your help.
    Eran
    02-06-2013 03:39 PM in reply to: ersegev
    You're welcome, Eran
    glad you got a solution
    Henrique
    02-06-2013 07:01 PM in reply to: ersegev
    ersegev wrote:
    Dear Henrique
    Eran
    another approach to consider is using entmakex.
    (defun LWPoly (lst cls)
      (entmakex
        (append (list (cons 0 "LWPOLYLINE")
    		  (cons 100 "AcDbEntity")
    		  (cons 100 "AcDbPolyline")
    		  (cons 90 (length lst))
    		  (cons 70 cls)
    	    (mapcar (function (lambda (p) (cons 10 p))) lst)
    lst = point list/vertex coordinates
    cls= Close/not close
    Will work regardless of osmode settings, plus you can supply other properties such as layer, color, lineweight etc....
    by adding the properties as an argument
    (defun LWPoly (lst cls lay lw col)
    HTH
    Member
    02-06-2013 10:45 PM in reply to: ersegev
    Once again,
    Many manu thanks for the wonderful help.
    Your solutions really inspire me.
    Eran
