Active Contributor
autocad4hbi
Message 11 of 16 (186 Views)
Re: PIPE BREAK
04-26-2007 07:05 AM in reply to: SRAUSCH
Thanks for your response!
I followed your instructions, but when I call the program I get an "unknown command" error. The file is in the directory that is listed in both the "Support File Search Path" and the "Working Support File Search Path". When I load the file I receive the message filename "successfully loaded" so that appears to be working, but then I get the error when I type the filename.
Any ideas?
Distinguished Contributor
andrew_nao
Message 12 of 16 (186 Views)
Re: PIPE BREAK
04-26-2007 07:41 AM in reply to: SRAUSCH
it could be there is an error in the code
what is the code that you are trying to run? did you obtain it from here or
somewhere else?
wrote in message news:5565318@discussion.autodesk.com...
Any ideas?
Active Contributor
autocad4hbi
Message 13 of 16 (186 Views)
Re: PIPE BREAK
04-26-2007 07:45 AM in reply to: SRAUSCH
I tried the first 2 in this discussion.
andrew_nao
Message 14 of 16 (186 Views)
Re: PIPE BREAK
04-26-2007 01:48 PM in reply to: SRAUSCH
what code are you trying to run that isnt working?
wrote in message news:5565407@discussion.autodesk.com...
Active Contributor
autocad4hbi
Message 15 of 16 (186 Views)
Re: PIPE BREAK
04-26-2007 02:11 PM in reply to: SRAUSCH
I tried the one from C. Witt on this discussion that begins -
;DRAW PIPE BREAK
(defun c:smileytongue:b ()
(setq peacc (getvar "peditaccept"))
- etc. etc. etc.
Active Contributor
VeronicaSmith5891
Message 16 of 16 (128 Views)
Re: PIPE BREAK
09-08-2011 09:39 AM in reply to: andrew_nao
I've been looking for a way to do this as well.  I remember the old RCUT and after reading this I just made my first lsp file (Thanks to the instructions on how to make an lsp code).  It worked perfect.  I couldn't believe it was so easy!
